Touch Pad Project - Problem with FeatherS2
by dsheeran on Thu May 13, 2021 5:21 pm
I am trying to do the Touch Pad tutorial and am having some trouble doing it with a Feather S2. This is the error I get...
code.py output:
No SD card found: no SD card
File "code.py", line 34, in <module>
File "adafruit_featherwing/tft_featherwing_35.py", line 34, in __init__
File "adafruit_featherwing/tft_featherwing.py", line 67, in __init__
File "adafruit_stmpe610.py", line 281, in __init__
RuntimeError: Failed to find STMPE610! Chip Version 0xffff. If you are using the breakout, verify you are in SPI mode.
Code done running.
I used the library packages from the 6.x bundle. I kept the circuit python version that comes with the S2 because it never shows up in Windows Explorer when I try to get into boot mode. So I cannot tell what version of Circuit Python came on the Feather. I do have a 8GB newly formatted SD drive in the slot.
Can someone please help me?
dsheeran
Re: Touch Pad Project - Problem with FeatherS2
sdf
dsheeran
by adafruit_support_mike on Fri May 14, 2021 2:08 am
Post a photo showing you hardware and connections and we'll take a look. 800x600 images usually work best.
by dsheeran on Sat May 15, 2021 10:10 am
Here's the pictures you asked for. I'm sending a couple. Please let me know what you think. Thanks.
dsheeran
by adafruit_support_mike on Sat May 15, 2021 7:56 pm
Thank you. The solder joints on the Feather look good.
What are you using as a power source?
by dsheeran on Sun May 16, 2021 7:23 am
My PC since I'm doing development.
dsheeran
