So my feather + propmaker were working fine. Soldered everything, still working fine. Was about to assemble my project, tested one more time- and now I just get an orange flash- then nothing. I removed the 3.7v battery and went straight to USB, same results. PC does not find the circuitpy drive either.
Help me forum moderator! You're my only hope!
feather just flashes orange- and then nothing!!
- Ozrail99
- dastels
Re: feather just flashes orange- and then nothing!!
Let's work from the simplest case. disconnect everything from the feather and see if it will work. Then add the PropWing without anything attached. Does it still work. Then add one thing at a time, check whether it works each time.
- Ozrail99
I was afraid you'd say that- everything is soldered... sighs...
- dastels
I was afraid you'd say that.
Did it pick up a bit of wire or something that could be shorting something? Are all the connections still good/solid/not-broken-off?
- Ozrail99
Cleaned up all my solders- they looked good to start, but what the heck...
Now when I start up, I get green, then yellow, then 7 yellow flashes.
Here's what the serial monitor says:
code.py output:
File "code.py", line 70, in <module>
RuntimeError: No pull up found on SDA or SCL; check your wiring
Code done running.
Here's Line 70:
code.py output:
Code done running.
Here's Line 70:
i2c = busio.I2C(board.SCL, board.SDA)
