Hello all, I'm not super versed in these matters, so please be patient. I want to control two dotstar rings and one dotstar strip with a feather board. The rings would be in parallel (I'm thinking), but how would you differentiate in Circuit Python the different devices? Can a feather board control three different DotStar devices? By this I mean, you could hammer out some code to tell the rings to randomly flash the LEDs in the ring while the strip did a chase sequence in a specific color.
I hope this question makes sense. Thank you to anyone who can answer me.
How to control different DotStar devices with a Feather
- Osglith
- dastels
Re: How to control different DotStar devices with a Feather
I would (and I have many times) connect them together into one line string of dotstars (this is the beauty of NeoPixels and DotStars). Then treat each ring/strip as a separate group of pixels. Do all the updates to the individual pixel colors and show() the whole thing at the end.
Here's one project that uses a ring, and a couple jewels to add color/light to a couple D&D scenery pieces (a stature holding a bowl of fire with a fiery light inside it's mouth, as well as a magic floor circle.
There's also this module I wrote to slice a strip into multiple logical strips that can be used independently: https://github.com/dastels/circuitpython_neopixel_zones
Both of those use NeoPixel, but you'd just need to change them to use the DotStar module/class.
- Osglith
Hi Dave, Thanks for the reply and the code. Just so I understand (and hopefully this will help others like me).
For this example let's say I have two NeoPixel 24 pixel Rings and one two-meter strip of 60 pixel per meter NeoPixel. For this example, I'm using all 120 neopixels. So if I wanted ring, strip, ring. I would wire the output data (plus power) from the first ring to the NeoPixel strip, then do that to the last ring. Using your code, I would then assign "zones", so pixels 1-25 is one zone (the first ring)(your code says last plus one so a 24 pixel ring would be 1-25, correct?), 26-121 would be my second zone (the dot star strip) and pixels 122-147 would be my last ring. Then I would do my effects to zone 1, zone 2 or zone 3 using the standard library commands.
Am I understanding this correctly? Thanks again for your time and reply!
- dastels
Pixels 0-23 would the first ring, 24-143 would be the strip, and 144-167 would be the second ring.
With a 2m strip you probably want to connect 5v & ground from the power source to the power & ground lines at each end of the strip. And you'll want an external supply, 5v at probably 5A, depending on how you'll be using the pixels. See https://learn.adafruit.com/adafruit-neopixel-uberguide for everything about NeoPixels and https://learn.adafruit.com/adafruit-dotstar-leds for everything about DotStars.
Finally, yes, once you set up the zone, you use each of them like you would a single strip.
That zone module is written for NeoPixels and will probably need some light tweaking to use with DotStars (probably just the NoePixel/DotStar module/class references).
- Osglith
Dave, you are awesome. This all makes sense and I'm really excited to try it all out. I'm going to try and figure out the power as I want all this to work off battery if I can (but I also want to include a stepper motor and a sound feather wing - so it will all draw a lot of power I'm guessing). You really helped so much, again thanks!
- dastels
LEDs are power hungry, motors can be as well. You can usually figure out roughly how much power everything will need.
