What is the state of GPIO pins during upload?
BAleiHi
Post by BAleiHi »
I have an Adalogger, Feather M0 and with a scope on D12 I see a noisy 3.3V while uploading a sketch. The first thing I do in the setup code is set the pinMode and do a digitalWrite LOW which brings it back to 0. But the pin is connected to a valve that opens when HIGH and I don't want it to open when I upload a new or updated sketch (the valve opens a vacuum that I want to release only under very specific circumstances). And for sketches that don't deal with the pin, it stays high. Is that the default for all the pins? Can I change it?
Thanks.
jevada
Re: What is the state of GPIO pins during upload?
Post by jevada »
In most controllers, GPIO pins that are floating after a reset. If your valve opens on a Vfloat and you need the pin to be low, you should add hardware to (weakly) pull the pin low. A pull-down resistor (let's say some 47k or so) usually will suffice.
BAleiHi
Post by BAleiHi »
Thank you jevada,
I tried that - with a 47K and a 4.7K resistor and I'm still getting the issue. To be clear, I connected the resistor between the pin controlling the valve (D12) and ground. It appears that both D11 and D12 are set high during upload, with or without the resistor. The signal to them does not appear to be floating...it's definitely up at 3.3 V, but there is noise on it for part of the time. See below:
My guess is that the "noise" has something to do with the serial communication during upload since it's very predictable. I also note that the base voltage is about 2.8V, not 3.3V. Any other thoughts?
westfw
Post by westfw »
Some SAMD21 bootloader support loading over either the serial or the USB port. You might be seeing attempts to allow serial uploading, even though the feather uploads over USB.
