Here is some of the example code (note the pins have been updated from the samples to match the Huzzah32):
#include <SPI.h>
#include <Wire.h>
#include "Adafruit_STMPE610.h"
// Pick one of three wiring options below!
// Option #1 - uses I2C, connect to hardware I2C port only!
// SCL to I2C clock (#A5 on Uno) and SDA to I2C data (#A4 on Uno)
// tie MODE to GND and POWER CYCLE (there is no reset pin)
//Adafruit_STMPE610 touch = Adafruit_STMPE610();
// Option #2 - use hardware SPI, connect to hardware SPI port only!
// SDI to MOSI, SDO to MISO, and SCL to SPI CLOCK
// on Arduino Uno, that's 11, 12 and 13 respectively
// Then pick a CS pin, any pin is OK but we suggest #10 on an Uno
// tie MODE to 3.3V and POWER CYCLE the STMPE610 (there is no reset pin)
#define STMPE_CS 32
#define STMPE_SDO 19 // SPI MISO
#define STMPE_SDI 18 // SPI MOSI
#define STMPE_SCK 5 // SPI CLOCK pin
//Adafruit_STMPE610 touch = Adafruit_STMPE610(STMPE_CS);
// Option #3 - use software SPI, connect to *any* 4 I/O pins!
// define the following pins to whatever 4 you want and wire up!
// Tie MODE to 3.3V and POWER CYCLE the STMPE610 (there is no reset pin)
Adafruit_STMPE610 touch = Adafruit_STMPE610(STMPE_CS, STMPE_SDI, STMPE_SDO, STMPE_SCK);
Serial.println("Adafruit STMPE610 example");
Serial.flush();
// if using hardware SPI on an Uno #10 must be an output, remove line
// if using software SPI or I2C
// If using I2C you can select the I2C address (there are two options) by calling
// touch.begin(0x41), the default, or touch.begin(0x44) if A0 is tied to 3.3V
// If no address is passed, 0x41 is used
delay(500);
if (! touch.begin()) {
Serial.println("STMPE not found!");
while(1);
Serial.println("Waiting for touch sense");
touch.begin()
