After flashing a sketch everything works fine. The issue I have is after powering down and the powering up, the nRF52832 goes directly into DFU mode. I suppose there my be something in the sdk_config.h file that is causing this to occur. I am using Arduino 1.8.15.
Any insight will be appreciated.
Craig H.
This occurs even when Basic Blink is flashed.
Adafruit Bluefruit nRF52832 sdk_config.h file location
- craighoffman
- mikeysklar
Re: Adafruit Bluefruit nRF52832 sdk_config.h file location
Craig,
Is there anything else connected to the controller? Do you see the same behavior when the power supply is USB connected to a PC versus a USB wall plug?
Which bootloader are you running?
https://learn.adafruit.com/bluefruit-nr ... bootloader
- craighoffman
I see the same behavior when only battery powered. I otherwise connect to usb on computer. Thank you.
- mikeysklar
And the bootloader version you are on?
- craighoffman
I believe it is
0.2.8_s132_6.1.1
0.2.8_s132_6.1.1
- craighoffman
I've located feather_nrf52832_bootloader-0.6.1_s132_6.1.1.zip
I don't see how to flash it to my board.
- mikeysklar
@craighoffman,
You can flash the bootloader to your board using the Arduino IDE or via command line utility adafruit-nrfutil. You can use the same link I provided last time for instructions.
Be sure to unzip the downloaded file. There is another zip within that zip that is your bootloader to upload. Confusing, I know.
- craigcooper
I am starting with a double reset to get the PYGAMERBOOT mounted.
Dragged that file onto the drive, GREEN lights changed to all whitish purple\?
The screen remains dark.
- Craig
- Craig
- mikeysklar
Craig,
How did we got from updating the bootloader on a nRF52832 device to the PYGAMER bootloader update?
