I'm looking to get an ESP32 based audio development board for a robotics project, but the one I'm eyeing, ESP32-LyraT, does not have PWM pins available to drive a Neopixel chain and 2-3 micro servos that I also need to have in the project. It does have I2C out, which is why I am looking at the 8-Channel PWM or Servo FeatherWing to control that. Servo control looks fairly straightforward, but I'm uncertain about running the Neopixels off of it.
Can Neopixels be run off this 8-Channel PWM Featherwing at all? And if so, can they be run in parallel with micro-servos? (By parallel, they can be given orders sequentially, I just mean that servos and neopixels will be connected to the same board).
Thanks in advance!
8-Channel PWM or Servo FeatherWing for Neopixels and servos?
- MARCoTechLLC
Re: 8-Channel PWM or Servo FeatherWing for Neopixels and ser
Neopixels do not use PWM and cannot be driven by a PWM board. They can be controlled directly via the ESP32. https://blog.adafruit.com/2018/08/16/es ... dprinting/
An ESP32 can also control servos directly. Although a separate PWM/Servo board is a good idea to avoid timing issues between servo pulses and neopixel communication.
