I started to built a data logger for GPS and acceleration with the Feather M0 Adalogger, the UltimateGPS Breakout V3 and the LSM9DS1. I followed the adafruit tutorials and combined the example code from the libraries (see below in code). When logging only GPS OR acceleration readings everything works fine. However, when combining both in in one loop the GPS reading becomes useless. When printing last NMEA to the serial the sentences are broken.
Wiring: GPS on RX and TX, LSM9DS1 on SDA and SCL. The wiring and the soldering should be fine as everything works as expected when using only the UltimateGPS or the Accelerometer alone
I'm new to all coding and the arduino world, so any help is highly appreciated!! Thanks in advance.
#include <SD.h>
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_GPS.h>
#include <Adafruit_LSM9DS1.h>
#include <Adafruit_Sensor.h> // not used in this demo but required!
const int chipSelect = 4;
#define GPSSerial Serial1
Adafruit_GPS GPS(&GPSSerial);
#define GPSECHO false
uint32_t timer = millis();
uint32_t timer2 = millis();
// i2c
Adafruit_LSM9DS1 lsm = Adafruit_LSM9DS1();
#define LSM9DS1_SCK A5
#define LSM9DS1_MISO 12
#define LSM9DS1_MOSI A4
#define LSM9DS1_XGCS 6
#define LSM9DS1_MCS 5
void setupSensor()
// 1.) Set the accelerometer range
lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_2G);
//lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_4G);
//lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_8G);
//lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_16G);
// 2.) Set the magnetometer sensitivity
lsm.setupMag(lsm.LSM9DS1_MAGGAIN_4GAUSS);
//lsm.setupMag(lsm.LSM9DS1_MAGGAIN_8GAUSS);
//lsm.setupMag(lsm.LSM9DS1_MAGGAIN_12GAUSS);
//lsm.setupMag(lsm.LSM9DS1_MAGGAIN_16GAUSS);
// 3.) Setup the gyroscope
lsm.setupGyro(lsm.LSM9DS1_GYROSCALE_245DPS);
//lsm.setupGyro(lsm.LSM9DS1_GYROSCALE_500DPS);
//lsm.setupGyro(lsm.LSM9DS1_GYROSCALE_2000DPS);
void setup()
Serial.print("Initializing SD card...");
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
Serial.begin(115200);
// 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
GPS.begin(9600);
// uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
// uncomment this line to turn on only the "minimum recommended" data
//GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
// For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
// the parser doesn't care about other sentences at this time
// Set the update rate
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
// For the parsing code to work nicely and have time to sort thru the data, and
// print it out we don't suggest using anything higher than 1 Hz
// Request updates on antenna status, comment out to keep quiet
GPS.sendCommand(PGCMD_ANTENNA);
delay(1000);
// Ask for firmware version
GPSSerial.println(PMTK_Q_RELEASE);
while (!Serial) {
delay(1); // will pause Zero, Leonardo, etc until serial console opens
Serial.println("LSM9DS1 data read demo");
// Try to initialise and warn if we couldn't detect the chip
if (!lsm.begin())
Serial.println("Oops ... unable to initialize the LSM9DS1. Check your wiring!");
while (1);
Serial.println("Found LSM9DS1 9DOF");
// helper to just set the default scaling we want, see above!
setupSensor();
void loop() //write readings of both sensores on SD card in two seperate files
motion();
location();
void location()
char c = GPS.read();
// if you want to debug, this is a good time to do it!
if (GPSECHO)
if (c) Serial.print(c);
// if a sentence is received, we can check the checksum, parse it...
if (GPS.newNMEAreceived()) {
// a tricky thing here is if we print the NMEA sentence, or data
// we end up not listening and catching other sentences!
// so be very wary if using OUTPUT_ALLDATA and trying to print out data
Serial.print(GPS.lastNMEA()); // this also sets the newNMEAreceived() flag to false
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
if ( timer > millis () ) timer = millis () ;
if (millis() - timer > 10000) {
timer = millis(); // reset the timer
timer2=millis();//timer2 needed to merge data of accel. to real time of GPS postprocessing
File dataFile = SD.open("location.txt", FILE_WRITE);
if (dataFile) {
//time and date
dataFile.print(timer2);
dataFile.print(',');
dataFile.print(GPS.day,DEC);dataFile.print('/');
dataFile.print(GPS.month,DEC);dataFile.print('/');
dataFile.print(GPS.year,DEC);
if (GPS.hour<10) {dataFile.print('0') ;}
dataFile.print(GPS.hour, DEC);
dataFile.print(':');
if (GPS.minute<10) {dataFile.print('0') ;}
dataFile.print(GPS.minute,DEC);
if (GPS.seconds<10) {dataFile.print('0') ;}
dataFile.print(GPS.seconds,DEC);
dataFile.print('.');
if (GPS.milliseconds<10) {dataFile.print('00') ;}
else if (GPS.milliseconds > 9 && GPS.milliseconds < 100) {
dataFile.print("0");
dataFile.print(GPS.milliseconds);
//location
if (GPS.fix){
dataFile.print(GPS.latitude,4);dataFile.print(GPS.lat);dataFile.print(',');
dataFile.print(GPS.longitude,4);dataFile.print(GPS.lon);dataFile.print(',');
dataFile.print(GPS.speed);dataFile.print(',');
dataFile.print(GPS.angle);dataFile.print(',');
dataFile.print(GPS.altitude);dataFile.print(',');
dataFile.println((int)GPS.satellites);
dataFile.close();
else{
dataFile.print("NA,");
dataFile.println("NA");
dataFile.close();
else {
Serial.println("error opening datalog");
delay (1000) ;
return ;
void motion()
lsm.read(); /* ask it to read in the data */
/* Get a new sensor event */
sensors_event_t a, m, g, temp;
lsm.getEvent(&a, &m, &g, &temp);
File dataFile = SD.open("ACCLOG.txt", FILE_WRITE);
if (dataFile){
dataFile.print(a.acceleration.x);dataFile.print(',');dataFile.print(a.acceleration.y);dataFile.print(',');dataFile.print(a.acceleration.z);dataFile.print(',');
dataFile.print(m.magnetic.x);dataFile.print(',');dataFile.print(m.magnetic.y);dataFile.print(',');dataFile.print(m.magnetic.z);dataFile.print(',');
dataFile.print(g.gyro.x);dataFile.print(',');dataFile.print(g.gyro.y);dataFile.print(',');dataFile.println(g.gyro.z);
dataFile.close();
delay(200);
else {
Serial.println("error opening acclog");
delay (1000) ;
return ;
