FeatherS2 with OLED 128x64 Featherwing no display
joezilla86
Post by joezilla86 »
I'm trying to get an OLED Featherwing to work with a FeatherS2. I have tried connecting via the QT port and stacking headers, and neither is able to find the featherwing. I'm getting a "ValueError: Unable to find I2C display at 3c". I've also tried to connect the featherwing to a QT PY through the QT connector and am still not getting any connection. I have successfully connected other featherwings, including daisy chained through the non-working OLED wing.
I'm trying to use exactly the code from https://learn.adafruit.com/adafruit-128 ... cuitpython but nothing shows up on the screen at all.
I've also tried scanning the i2c bus with:
import board
i2c = board.I2C()
while not i2c.try_lock():
    pass
i2c.scan()
Which returns
. I can get output from this scan if other featherwings are connected, but still not from the OLED board.
joezilla86
Re: FeatherS2 with OLED 128x64 Featherwing no display
Upon closer inspection I found that the OLED is cracked. One of the corners is chipped off and there is a crack that goes along where the flex connector joins to the screen.
Cracked OLED.jpg (530.2 KiB) Viewed 60 times
Franklin97355
Post by Franklin97355 »
I don't know what to test that you haven't so Contact [email protected] with a link to this thread and they will get you a new Featherwing.
