I was wondering if there was an issue with the Adafruit_AHTX0 library and the Feather PR2040.
The Feather PR2040 using the STEMMA connector freezes every time I try to initialize the AHT20.
I tried the same AHT20 on the Metro M4 using the STEMMA to 4-Pin cable and it works great.
Is this an issue with Arduino IDE not yet supported for the Feather RP2040?
Luc
issues with feather RP2040 and AHT20
- adafruit_support_carter
Re: issues with feather RP2040 and AHT20
The STEMMA connector on the Feather RP2040 ends up being Wire1 instead of Wire. So change your call to begin() to be like:
aht.begin(&Wire1)
- ltheoret
Thank you. Did not see that. Thanks again. :)
Luc
Luc
