Feather M0 Adalogger with no USB
- rinitech
I have an application built around the Adalogger. Is it possible to get the board without the USB connector or battery header? I need to be able to add a different USB connector on leads rather than surface mounted.
- mikeysklar
Re: Feather M0 Adalogger with no USB
@rintech,
The Adalogger will always come with battery JST connector and micro USB plug.
Three options come to mind. None of them ideal, but workable solutions:
1) Consider is using a different model of the Adafruit Feather with the Adalogger Featherwing.
https://www.adafruit.com/product/2922
2) Remove the two connectors yourself and replace them with your own types. It's cheap and not a big deal to do. Plus rapid warranty invalidation is fun.
3) Use an external micro SD breakout board and select a different controller board. The only problem here is we do not have a lot of boards without micro-b / micro-c plugs. Occasionally the USB-A PCB style plug.
https://www.adafruit.com/product/4682
