I attached an MAX3232 RS232 transceiver to the RX and TX pins on a Adafruit Feather M4 CAN Express with ATSAME51 and the USB serial port has died. The board still functions otherwise. Is there an issue with the way I connected things?
RS232 kills USB serial
- jevada
Re: RS232 kills USB serial
Looks like you swapped RX_D0 and TX_D1, resulting in a possibly (too) high current through TX. I'm afraid you burned either that MAX3232 or your feather's output.
- pateco
I see, I was pretty sure it was dead. Are the RX and TX pins shared with USB Serial? Are there other serial hardware ports exposed, i.e. Serial1, Serial2, Serial3, ...?
