Adafruit RGB Matrix Featherwing Kit Terminal Block?
TianaCo
Post by TianaCo »
I ordered a Adafruit RGB Matrix Featherwing Kit (For RP2040, M0 and M4 Feathers) and the terminal block piece doesn't look like the one on the website and I'm not sure how to use it.
Please advise!
dastels
Re: Adafruit RGB Matrix Featherwing Kit Terminal Block?
Post by dastels »
That looks like a pin jumper , nor a terminal block and I have no idea why it would be with that board. The board should come with the items shown here: https://learn.adafruit.com/assets/59613 Can you post a photo like that so I can see if anything else is off about it?
TianaCo
Post by TianaCo »
These are the pieces it came with. I received the package, I noticed something was off and they resent it and I got the exact same components. I don't think I can use the board without the terminal block. And customer support just sent me here.
dastels
Post by dastels »
This is very odd. Can you post a photo of the packaging? There should be a lot/batch number that can be used to investigate the problem. I'm inferring that you have two matrix featherwings, each missing the terminal block? If that's the case please post photos of both pieces packaging, assuming they are still around.
TianaCo
Post by TianaCo »
here are the two bags
dastels
Post by dastels »
Thanks. I'll pass that on.
Please email [email protected] with a link to this thread, your order number, and request the "replacement" of two 5.08mm terminal blocks that were missing.
