Win10 includes the necessary USB serial drivers and you have a COM port and USB ID. The board is hardware sound, but it looks like you need to install the UF2 bootloader.
https://circuitpython.org/board/adafrui ... r_esp32s2/https://github.com/adafruit/tinyuf2/rel ... -0.5.2.zipInstall, Repair, or Update UF2 Bootloader
Latest version: 0.5.2
The UF2 bootloader allows you to load CircuitPython, MakeCode, and Arduino programs. The bootloader is not CircuitPython. If a UF2 bootloader is installed, you can check its version by looking in the INFO_UF2.TXT file when the BOOT drive is visible (FTHRS2BOOT, MAGTAGBOOT, HOUSEBOOT, etc.)
It is not necessary to reinstall a UF2 bootloader you unless a BOOT drive is not visible when in UF2 bootloader mode, or you know of a problem with your current UF2 bootloader.
If a UF2 bootloader has never been installed on the board, or the UF2 bootloader was removed by erasing or overwriting the flash, the UF2 bootloader must be installed in order to flash .uf2 files onto the board. .bin files can be uploaded without a UF2 bootloader, using the Adafruit WebSerial ESPTool or esptool.py.
Note: update.uf2 files are not currently working on ESP32-S2 boards.
Important: this will erase previously flashed firmware and sketches from the board, but needs to be perfomed only once.
Unzip to find the file combined.bin.
Place board in bootloader mode:
Plug board into a USB port on your computer using a data/sync cable. Make sure it is the only board plugged in, and that a charge-only cable is not being used.
Press and hold down the BOOT or 0 button.
Press and release the RESET or RST button.
Release the BOOT button.
Upload combined.bin (Google Chrome 89 or newer):
Open Adafruit WebSerial ESPTool in a new window/tab.
Select 460800 Baud from the pull-down menu (top-right).
Click Connect (top-right).
Select the COM or Serial port from the pop-up window.
After successful connection, click Erase.
After successful erase, click any Choose a file..., then locate and select the combined.bin file unzipped earlier.
After successfully choosing combined.bin, click Program.
After the TinyUF2 firmware update is complete, press the RESET button on the board. A new drive BOOT should be visible in your file browser.
After you update, check INFO_UF2.TXT to verify that the bootloader version has been updated. Then you will need to load or reload CircuitPython using the .uf2 file.
