Super excited about the new feather lines with the integrated humidy/temp sensor.
I want to 3d print some cases for them (battery powered) and place them around the house (e.g. indoor sensor).
My searches on thingiverse hasn't found many matches, and I am wondering how best to design the case for sampling and airflow? (assuming lipo battery power)
I don't necessarily need a full case STL, more just interested in tips for laying it all out, and avoiding the heat from the sensor of skewing the readings.
Thanks for reading!
3d printing a case for feather esp32 w/BME280 sensor?
- laserdog
Re: 3d printing a case for feather esp32 w/BME280 sensor?
I'd lay it out with the board on-edge, and vents top and bottom. That will allow convective air flow over the surface of the board to minimize heat buildup inside the case.
- laserdog
Sounds good... By on edge you mean, lying upright on it's long edge, right?
Looking at the board... Am I dumb, or I can't even see where the BME280 sensor *is*?
https://cdn-shop.adafruit.com/970x728/5303-08.jpg
I assume it is on "the top" of the board with everything else, but for the life of me I can't see where it is.
Yes, on the long edge. The BME280 is almost dead-center on the board. It is the small square metal can with the little hole in the top. Right between the QT connector and the esp32 module.
