Hi I am trying to read a temperature with HUZZAH32 Feather and DS18B20 by setting up a webserver on Arduino Create. I included the // Import required libraries
#ifdef ESP32
#include <WiFi.h>
#include <ESPAsyncWebServer.h>
from Rui Santos excellent tutorial at https://randomnerdtutorials.com/esp32-d ... duino-ide/ But the #include <ESPAsyncWebServer.h> errors out. Almost certainly a newbie error, so if anyone has any advice on what I should be including it would be great. BTW if I've posted in the wrong index, apologies.
Chris
Webserver for Adafruit Huzzah32 Feather
- ChristopherGlasow
- Franklin97355
Re: Webserver for Adafruit Huzzah32 Feather
If you put preferences to verbose what is the exact error message that you receive?
What board are you compiling for in the ide?
- ChristopherGlasow
Hi franklin97355,
I get the error: /tmp/223826492/sketch_nov24a/sketch_nov24a.ino:9:33: fatal error: ESPAsyncWebServer.h: No such file or directory
compilation terminated.
Error during build: exit status 1
I am compiling the Adafruit Hazzah32 Feather and using Arduino Create.
Many thanks
Chris
Many thanks
Chris
- Franklin97355
Did you download and install the library?
- ChristopherGlasow
Hi Franklin97355,
No I assume that using Arduino Create all the libraries are available on the server, have I got that wrong?
Chris
Chris
- adafruit2
tbh we don't use Create for ESP32 - Arduino Create is best used for official boards. can you use the desktop IDE?
- ChristopherGlasow
Hi Adafruit2,
No I have a problem loading drivers that use the IDE on my iMAC, it all runs fine when I use Arduino Create, but I always seem to have probems using the IDE. So what you are saying is that the libraries for the Adafruit HAZZAH32 Feather are not avilable for Arduino Create?
I appreciate your help.
thanks
Chris
thanks
Chris
- ChristopherGlasow
Hi Adafruit2
I will try again to load the drivers for the IDE. Can you give me the URL for the HAZZAH32 libraries that I place into 'Additional Boards Manager URLs' in Preferences please?
Thanks again for your help.
Chris
Chris
- Franklin97355
Take a look at this learn article https://learn.adafruit.com/add-boards-a ... v164/setup Then search for huzzah (or esp)
- ChristopherGlasow
Hi Franklin97355 and Adafruit2
All sorted, many thanks for your help.
