Hello! I just finished setting up and compiling on my Adafruit Bluefruit 32u4 for use with Neopixel, for the Halo Energy Sword project. After I compiled the software, my neopixels work but not as intended. I am using RGBW LED's instead of RGBs. When I use the Bluefruit connect app and change the color to something other than white, the pixels are in an alternating pattern of red, green and blue. For instance, when I set the strip to green, the first led in the strip is green. But the next ones go blue-red-green-blue and so on.
Is this because I'm using a RGBW strip? Should I use a RGB strip instead? Or is it my software?
RGBW Neopixel not working?
- Shelby33
- Screenshot_20211125-043115_Bluefruit Connect.jpg (191.76 KiB) Viewed 270 times
- 20211125_043110.jpg (299.53 KiB) Viewed 270 times
Re: RGBW Neopixel not working?
In your software, you need to specify that you are using an RGBW strip.
https://learn.adafruit.com/adafruit-neo ... aq-2894507
