When I try to run the SdFat_format sketch in the Adafruit SPIFlash library (https://github.com/adafruit/Adafruit_SP ... Fat_format), I get the following error message
In file included from C:\Users\jaysj\Documents\Arduino\libraries\FatFs\src/ff_gen_drv.h:58,
from C:\Users\jaysj\Documents\Arduino\libraries\FatFs\src/FatFs.h:42,
from C:\Users\jaysj\AppData\Local\Temp\arduino_modified_sketch_230095\sketch_nov26c.ino:24:
C:\Users\jaysj\Documents\Arduino\libraries\FatFs\src/ff.h:29:10: fatal error: ffconf.h: No such file or directory
29 | #include "ffconf.h" /* FatFs configuration options */
compilation terminated.
exit status 1
Error compiling for board Adafruit Feather nRF52840 Sense.
So, I tried downloading and pasting the ffconf.h file into the library, but then I get this error:
WARNING: library FatFs claims to run on stm32 architecture(s) and may be incompatible with your current board which runs on nrf52 architecture(s).
from C:\Users\jaysj\AppData\Local\Temp\arduino_modified_sketch_427745\sketch_nov26c.ino:24:
C:\Users\jaysj\Documents\Arduino\libraries\FatFs\src/ff.h:32:2: error: #error Wrong configuration file (ffconf.h).
32 | #error Wrong configuration file (ffconf.h).
exit status 1
Does this mean that my sense is incompatible with the FatFs library, or is there something else I need to change?
SdFat_format sketch not working w Feather nRF52480
- jaysjagani
- hathach
Re: SdFat_format sketch not working w Feather nRF52480
it seems to be libraries incompatible, try to temporarily remove the Arduino\libraries\FatFs then compile gain. The present of that library with ff.h is the issue, the SPIFlash example does not need that FatFS to run.
