Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 231724 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26793 / 32768 - code in IRAM (IRAM_ATTR, ISRs...)
DATA : 1496 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 876 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25608 ) - zeroed variables (global, static) in RAM/HEAP
/Users/bujones/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-size -A /var/folders/bx/gtq_wjjj1t1clxdck0rp3wyr0000gn/T/arduino_build_325178/ESP8266.ino.elf
Sketch uses 260889 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 27980 bytes (34%) of dynamic memory, leaving 53940 bytes for local variables. Maximum is 81920 bytes.
esptool.py v3.0
Serial port /dev/cu.usbserial-AH03IMOT
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 8c:aa:b5:77:2c:78
Uploading stub...
File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/upload.py", line 66, in <module>
esptool.main(cmdline)
File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 3575, in main
esp = esp.run_stub()
File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 722, in run_stub
self.mem_block(stub[field][from_offs:to_offs], seq)
File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 609, in mem_block
return self.check_command("write to target RAM", self.ESP_MEM_DATA,
File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 413, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 386, in command
p = self.read()
File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 331, in read
return next(self._slip_reader)
File "/Users/bujones/Library/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool/esptool.py", line 2636, in slip_reader
raise FatalError("Timed out waiting for packet %s" % waiting_for)
esptool.FatalError: Timed out waiting for packet header
I appreciate any assistance.
