I want to display sensor data on A LED matrix connected to a Adafruit RGB Matrix Bonnet & Pi Zero. The Pi is supposed to receive the data from an https://learn.adafruit.com/adafruit-fea ... le/pinouts but this not happening, and I would be grateful if someone can tell me how to fix this problem.
My wiring between the Feather & Pi are detailed in the attached image .
To test the connection I am running the following code on the Feather:
// https://roboticsbackend.com/raspberry-p ... unication/
Serial.begin(9600);
Serial.println("Hello from Arduino!");
delay(1000);
The Feather terminal window shows the following which is encouraging:
12:28:36.080 -> Hello from Arduino!
12:28:37.064 -> Hello from Arduino!
12:28:38.053 -> Hello from Arduino!
I am running the following test code on the Pi Zero:
# https://roboticsbackend.com/raspberry-p ... unication/
#!/usr/bin/env python3
import serial
if __name__ == '__main__':
ser = serial.Serial('/dev/serial0', 9600, timeout=3)
ser.reset_input_buffer()
while True:
if ser.in_waiting > 0:
line = ser.readline().decode('utf-8').rstrip()
print(line)
I am currently get no errors but no results from the Pi, when viewed on Thonny.
If I comment out "if ser.in_waiting > 0:", then the Thonny (Shell) output scrolls down with blank lines.
I have tried changing serial0 to serial1 with no better results.
Typing "ls -l /dev" on the Pi terminal includes the following rows in the output:
lrwxrwxrwx 1 root root 7 Dec 1 12:17 serial0 -> ttyAMA0
lrwxrwxrwx 1 root root 5 Dec 1 12:17 serial1 -> ttyS0
Can you please tell me why the Pi is not receiving the test message from the Feather?
Feather M0 LoRa module TX/RX UART connection to Raspberry Pi
- CluelessRic
- CluelessRic
Re: Feather M0 LoRa module TX/RX UART connection to Raspberr
It seems the problem is with the Feather M0, because I replaced it with a Sparkfun ESP8266 Thing Dev board, using the same wiring as above. Using the same Arduino sender code as above, the "Hello from Arduino" message is received on the Pi per attached screenshot.
Unfortunately the ESP8266 does not have the required transmission range for my project, so I still need to find out why the Feather won't connect to the Pi.
Any ideas how to get the Feather to send to the Pi?
- Franklin97355
Take a look at this user that had a similar problem:https://forum.arduino.cc/t/connecting-f ... lem/531104
- CluelessRic
This screen shot shows the Pi receiving a message from an ESP board; but it won't receive from the Feather board using same wiring and code!
- Thonny screen for ESP to Pi
- Thonny for ESP to Pi code.png (367.73 KiB) Viewed 167 times
- CluelessRic
Franklin, your link to a similar post seems to focus on logic level conversion, but in my case both the Feather and Pi boards use 3.3V logic?
- adafruit_support_carter
The TX/RX pins on the Feather are accessed via Serial1:
https://learn.adafruit.com/adafruit-fea ... -2825153-9
- CluelessRic
Hi Carter, as mentioned in my original post, I have already tried using the line "ser = serial.Serial('/dev/serial1', 9600, timeout=3)" in the Pi code, without success.
What else should I be doing to use Serial1?
- dastels
Use Serial1 instead of Serial in the Feather code. Serial is the USB/Serial connection.
- CluelessRic
Thanks for the advise Dave.
When I use "Serial1.begin(9600);" in the Feather code above, the Feather sends messages, but the Pi still receives nothing.
When I then also use "Serial1.println("Hello from Arduino!");" in the Feather code, the Feather does not send messages, and obviously the Pi receives nothing.
Should I do something else?
You will not see anything in the Serial Monitor if you only print to Serial1. Try printing to both Serial (for debugging) and Serial1 (for talking to Pi) in your Arduino sketch.
EDIT - you may also need to "enable" serial on the Pi. You can do that via rpi-config or by direct text file editing:
https://learn.adafruit.com/raspberry-pi ... 2827368-10
- CluelessRic
Hi Carter, I changed the Feather code to include both lines : Serial.println("Hello from Arduino!"); and Serial1.println("Hello from Arduino!"); .
Mt boot/config.txt file already included an uncommented line: enable_uart=1
Only when I changed the Pi code from serial1 to serial0 ie the code line: ser = serial.Serial('/dev/serial0', 9600, timeout=3) , did the messages finally start appearing in Thonny!
The messages also appear in the Pi's Terminal screen when I run the file.
Thanks for solving my problem!
I will now move to the next stage of this project; sending temperature data from the Feather to the Pi/display hat for LED matrix display purposes.
