FeatherS2 - ESP32-S2 Unable to Connect
by Masoric on Fri Dec 03, 2021 5:14 pm
I recently purchased a FeatherS2 - ESP32-S2 and it seems to be defective. However, I am hoping it just something that I am doing wrong.
At the most basic level it appears windows does not recognize it being plugged in.
When I plug in my other esp's 32s or 8266 I get a silicon Labs USB to UART Bridge COM Port (please see the attached picture).
However, when I plug in the FeatherS2 there is nothing.
Any suggestions would be appreciated.
Regards,
Masoric
- Masoric
- COM Ports.jpg (11.47 KiB) Viewed 352 times
- fultonbd
Re: FeatherS2 - ESP32-S2 Unable to Connect
I have had the same problem. I have a MacBook Air and my machine does not see the feather ESP32-S2 boards I purchased. On one of them I followed the instructions in your forum (viewtopic.php?f=57&t=185395) and updated the UF2 bootloader. My machine could then see this board, but when I dragged and dropped the circuitpython file (adafruit-circuitpython-adafruit_feather_esp32s2-en_US-7.1.0-beta.1.uf2) onto it circuitpython would not load. I cannot access anything on the board.
Brad
Brad
I have similar problem. viewtopic.php?f=57&t=185848
No COMM Port shows to be able to update the UF2 bootloader.
- adafruit_support_carter
Please try the recovery procedure shown here:
https://learn.adafruit.com/adafruit-esp ... tory-reset
- Masoric
No luck... I just get the following messagesadafruit_support_carter wrote:Please try the recovery procedure shown here:
Adafruit WebSerial ESPTool loaded.
Connecting...
Connected successfully.
Try to reset.
Timed out after 100 milliseconds
Error: Couldn't sync to ESP. Try resetting.
- adafruit2
@masoric if you're using arduino IDE, please try uploading a Blink sketch or something - get into the bootloader with boot+rst button and then select that COM port from the IDE to upload. that will clean up the bootloader as well!
@fulton try stable 7.0.0 release - that might work better than the beta, which is unstable
- fultonbd
I have tried to copy different releases onto my feather. Nothing ever gets copied and FTHRS2BOOT never changes its name.
Brad
Brad
- adafruit2
@fulton can you upload sketches with Arduino?
- fultonbd
I tried to upload the blink program using arduino and got the following error message:
Arduino: 1.8.13 (Mac OS X), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
IROM : 227612 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26768 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1252 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 672 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 24880 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 256304 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 26804 bytes (32%) of dynamic memory, leaving 55116 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
File "/Users/bradfulton/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/pyserial/serial/serialposix.py", line 265, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/cu.usbmodem14201'
During handling of the above exception, another exception occurred:
File "/Users/bradfulton/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "/Users/bradfulton/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool/esptool.py", line 2889, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "/Users/bradfulton/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool/esptool.py", line 237, in __init__
self._port = serial.serial_for_url(port)
Serial port /dev/cu.usbmodem14201
File "/Users/bradfulton/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/pyserial/serial/__init__.py", line 88, in serial_for_url
instance.open()
File "/Users/bradfulton/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/pyserial/serial/serialposix.py", line 268, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/cu.usbmodem14201: [Errno 2] No such file or directory: '/dev/cu.usbmodem14201'
the selected serial port serial.serialutil.SerialException: [Errno 2] could not open port /dev/cu.usbmodem14201: [Errno 2] No such file or directory: '/dev/cu.usbmodem14201'
does not exist or your board is not connected
esptool.py v2.8
instance.open()
- adafruit2
Adafruit Feather HUZZAH ESP8266 is the wrong board selected
- fultonbd
As soon as I posted the last message I realized I had used the wrong board. I downloaded the expressive esp32s2 board using the instructions at: https://docs.espressif.com/projects/ard ... ds-manager
I was able to pick my adafruit board.
I tried to upload the blink program and got the following error:
Arduino: 1.8.13 (Mac OS X), Board: "Adafruit Metro ESP32-S2, Enabled, Disabled, Disabled, Internal USB, Enabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi), QIO, 80MHz, 4MB (32Mb), 921600, None"
Sketch uses 218194 bytes (16%) of program storage space. Maximum is 1310720 bytes.
Global variables use 17932 bytes (5%) of dynamic memory, leaving 309748 bytes for local variables. Maximum is 327680 bytes.
Couldn't find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
I picked the only available port listed under Tools: Port and tried to upload blink again and got this error:
esptool.py v3.1
Serial port /dev/cu.Bluetooth-Incoming-Port
Connecting........_____....._____....._____....._____....._____....._____.....____An error occurred while uploading the sketch
_
A fatal error occurred: Failed to connect to ESP32-S2: Timed out waiting for packet header
esptool.py v3.1
_
- adafruit2
is also the wrong board
make sure you hold down BOOT then press reset button, to get the COM port to appear
is not ever the right port, that is always your OS bluetooth port
check your USB cable, try another computer, etc.
check
https://learn.adafruit.com/adafruit-esp ... -ide-setup
https://learn.adafruit.com/adafruit-esp ... rduino-ide
for deets :)
check
for deets :)
- fultonbd
I tried again with the correct board and don't get any ports listed except: /dev/cu.Bluetooth-Incoming-Port
- adafruit2
you are not entering bootloader mode correctly, see above!
Same here: NO COM port shows in Device Manger (win8.1 PC).
Yes, Holding down BOOT button then Press-release Reset button .
Neither Arduino IDE or the WebSerial ESPTool will work if NO COM port shows up.
Therefore the Factory Reset instructions DO NOT WORK.
