I've recently purchased FeatherWing OLED 128x64 through Digikey and plugged it in a Adalogger M0 board. The display is very, very dim. In fact, I only noticed something was 'visible' on the display after nightfall, when my lab was darker. Here's an image of the faint Adafruit splash screen when running a basic test program:
viewtopic.php?f=57&t=184282&p=896966&hi ... 64#p896966
Things I have tried:
- Using the setContrast function does change the contrast, but it can only be lowered (expected, as the screen starts at max contrast by default).
- Verified the 3.3V rail and the charge-pump output (11.6V)
- The usual continuity tests
Anything else I could try? Here's some more product pictures; the board looks perfectly fine otherwise.
Thanks for your help! :)
The problem seems similar to this recent post, except that in my case the display never worked:Very, very dim 128X64 oled display
- adafruit_support_carter
Re: Very, very dim 128X64 oled display
Thanks for the photos. We can replace this. We'd also be interested in getting that one back so we can investigate this. Are you in the US?
- takaharatan
Thanks that'd be awesome. I'm happy to send it back but I live in Japan so I'm not sure how that would work. Let me know if/how we can proceed.
In the meantime I went over the contacts of the display flat-flex (bad joint?) but it did not improve the situation.
OK, thanks. Let's just replace it and not worry about returning the one you have.
Send an email to [email protected] with a link to this thread and your order number and they can send you a replacement OLED display.
- takaharatan
Thanks! :-)
- takaharatan
I received the replacement display today: works like a charm!
Thanks for the great support!
- IMG_20211213_210730.jpg (62.56 KiB) Viewed 110 times
