When I try to compile I get an error, this error. Where can i find this missing library?
C:\Users\rchrd\Documents\Arduino\libraries\SoftwareSerial\src\SoftwareSerial.cpp:45:10: fatal error: util/delay_basic.h: No such file or directory
#include <util/delay_basic.h>
compilation terminated.
Multiple libraries were found for "Adafruit_ZeroDMA.h"
Used: C:\Users\rchrd\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.5\libraries\Adafruit_ZeroDMA
Not used: C:\Users\rchrd\Documents\Arduino\libraries\Adafruit_Zero_DMA_Library
Multiple libraries were found for "SD.h"
Used: C:\Users\rchrd\Documents\Arduino\libraries\SD
Not used: C:\Program Files (x86)\Arduino\libraries\SD
Compilation error: exit status 1}
#ifndef FlightComputer
#define FlightComputer
#if (ARDUINO >= 100)
#include <Arduino.h>
#else
#include <WProgram.h>
#endif
#include <TimerOne.h>
#include <SPI.h>
#include <SD.h>
#include <SoftwareSerial.h>
#endif
//Setup the radio tramsmiter and GPS serial port
SoftwareSerial RadioTX_Port(9, 10); // RX, TX
SoftwareSerial GPS_Interface(0,1); // RX, TX
Timer1 :: RadioTX_Interrupt
Timer1 :: Sample_Interrupt
Timer1 :: SerailData_Interrupt
class FightComputer{
public:
#define Safety_Key_Pin 6
#define DebounceTime 50;
//Set up SD card contorl & varables
// set up variables using the SD utility library functions:
Sd2Card SD_Card;
SdVolume SD_volume;
SdFile SD_root;
const int8_t SD_ChipSelect = 4;
const int8_t SD_Dect_Pin = 7;
void _SD_Card_Initialize();
