I recently purchased one of these for a project:
https://www.adafruit.com/product/1063
And I'm using a Feather M4 express. Since I've never used a mic in my projects before, I thought I'd start by reading this guide and changing what's needed to make it fit for the Feather M4.
https://learn.adafruit.com/sound-reacti ... ython-code
My end goal is to have the mic sense volume levels, plot and map the readings, and have a servo rotate from 0-180 based on how loud the the mic says the sound is.
I'm a little lost, however. I know the mic detects more than just volume, since it can record audio samples and all, I'm just not certain how to go about picking out that value.
I thought maybe I could pic apart the audio-levels meter part of the code featured in the guide and find the variable that changes based on the volume of the sound around it, but I can't get anything to respond the way I'd like. Every signal seems more-or-less random, jumping up and down rapidly.
Sensing Volume levels with Electret Mic
- Daft_vagabond
- dastels
Re: Sensing Volume levels with Electret Mic
I looked through that code and it's extracting volume information from the sound. A sound wave is a complex combination of sine waves. That's what a mic detects. Extracting the volume is a matter of sampling over time and computing a rolling average of the min/max values. That's what the guts of the code in that project does. So you seem to be on the right track.
- Daft_vagabond
From what I can tell, I followed everything in the guide and I'm still having issues.
I decided to follow the guide and get the mic and led string working normally, then afterwards I would start playing around with it.
I've confirmed and reconfirmed that I've done everything correctly. I copy-pasted the code, changed the LED pin to the pin I'm using, confirmed that the pin supports PWM, wired everything up properly, changed the length of my led string in the code to match the length of the string I'm using, and it still doesn't seem to be responding to any sounds I'm making. It seems to be acting totally random.
Even when sitting in complete silence, the led string idles at the top, most of the time. The readouts are telling the same story, that whatever values the board is sending are somewhere near the peak, consistently.
I tried adjusting the noise value a few different times, but that acts just the same. I'm gonna keep looking at everything just to make sure I followed everything 1:1, but I'm nearly certain that I have.
- Daft_vagabond
I just wanted to add that I've also tried adjusting the gain from the back of the mic, too.
- dastels
Can you post clean photos of the wiring & connections?
- Daft_vagabond
Sure thing!
(hastily taken just a moment ago)
- wiring.jpg (439.46 KiB) Viewed 165 times
- Daft_vagabond
I was fiddling around and happened to notice something. Right next to the EN pin, that resistor has a component next to it, I can see it in the macros on your site, but if you zoom into the picture I posted, mine doesn't have that, just five empty solder pads.
I don't have the know-how to determine if this would effect anything with what I'm doing, but it sure is weird and I thought I'd bring it up.
- dastels
Yeah, That's either the charger or the regulator. Since you have code running, I'm guessing that's the charger. In any case there's something missing. I doubt it would effect reading the mic, but it's not right.
Please email [email protected] with a link to this thread, your order number, and request the replacement of one Feather M4 Express.
- Daft_vagabond
Is there a way you might recommend me testing the mic itself? I tried the same project using the Arduino code instead and on a different board, I also replaced the pixel strip with a different one, just in case, and I'm still getting the same result. The readout says that the mic is bobbing around that same values, seemingly unaffected by the noise around it.
- dastels
Do you have an oscilloscope (or access to one)? That would let you look at the signal from the mic.
- Daft_vagabond
Yeah. Which things should I test? If the "OUT" pin looks fine, is there some other component on board I can test?
- dastels
If OUT of the board looks fine, then it's not an issue with the mic board. I'd look again at the software and the use of the analog input, then.
- Daft_vagabond
I'm definitely a bit stumped, now. I hooked the mic up to the oscilloscope, set it for 3v3, and it seems to be working fine. Every snap, pop, and hum I making into it gives me waves relative to the volume at which I produce them.
You mentioned looking again at the software and the use of the analog input. Could you elaborate on that for me?
- dastels
OK, the mic board works.
The next thing to look at is the wiring. make sure the connections are correct and good: replace the wires, move to a different area of the breadboard.
Then it's the code. This was written for a SAMD21 so it should just work on the SAMD51. Make sure you have the latest code by grabbing it directly from github: https://github.com/adafruit/Adafruit_Le ... nt/code.py
But your Feather does have a problem (missing charger) from fab, so there could be other issues.
- Daft_vagabond
Okay, I'll test this later when I'm able to.
I had an idea I wanted to ask about.
A few months back I had a project where I was measuring sound intensity in much the same way, except the signal was PWM rather than analog. I was having trouble calculating consistent averages, which was important because, just like this project, I only needed to keep track of the intensity of the sound, nothing else really mattered.
The route I ended up going with was sending the PWM through an RC filter. That smoothed everything out and gave me a nice, easily readable audio intensity level. I don't know if that sort of thing would work for an analog signal coming from a microphone, but I thought it worth asking.
