Is it possible to use this sensor (https://www.adafruit.com/product/4664#technical-details) with a feather huzzah without adding any additional hardware? Are there any library etc that I'd need to load? Also, if you could point me to an similar example using UART TTL input using Arduino IDE that would be much appreciated.
Thank you very much in advance.
UART TTL Input with Feather Huzzah
- dastels
Re: UART TTL Input with Feather Huzzah
Tx/Rx are used for the USB adaptor, but it looks like there are other UART serial you can use, maybe pins 15 & 13? In the worst case you can use software serial. See https://docs.arduino.cc/learn/built-in- ... are-serial. The sensor runs at 9600 baud, which is plenty slow enough for software serial to work great.
- mikeysklar
The Feather Huzzah ESP8266 hardware serial pins are linked into the USB console so using them for UART TTL communication is troublesome. Ideally another controlled would be selected as pretty much any other modern Feather will give you a second hardware UART TTL access for peripherals.
However, you can use software serial. Something like this:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(14, 12, 128);
mySerial.begin(9600);
if (mySerial.available()) {
serialData = mySerial.read();
