I have just purchased a Adafruit Feather RP2040 and Pico
I loaded up latest Circuit Python 7x. and tried to use mpy libraries, all showed up as wrong version.
Do mpy's work with the above?
Or should use py files?
Please advise.
Kind Regards Michael
Adafruit Feather RP2040 and mpy libraries
- dastels
Re: Adafruit Feather RP2040 and mpy libraries
Yes, they work with all boards. MPYs are hardware independent. They do have to match the version of CircuitPython you have. So for 7.x.x of CircuuitPython you'll need to use the 7.X bundle from https://circuitpython.org/libraries. The CircuitPython runtime (i.e. the UF2) IS hardware dependant. Be sure you have the one for your board.
- neradoc
Hi, you might be hitting a bug in the current bundle, please try using the previous release:
https://github.com/adafruit/Adafruit_CircuitPython_Bundle/releases/tag/20220614
- Whimick
Hi, should the version you suggest work, or should go back a few more weeks and those mpy's
Michael
Michael
- neradoc
The bug is fixed now, please try the latest bundle, and replace all the libraries on the board (deleting them all first is the easiest way to avoid forgetting one).
