upload sketches to M0 Express
- earthres
I HOPE this isn't a dumb question, but I can't get the M0 Express to upload ANY sketches. As far as I know I've installed all the the required board support. I've tried pushing the reset button twice. What am I doing wrong here??
- Attachments
- M0Express.jpg (61.85 KiB) Viewed 230 times
- adafruit_support_carter
Re: upload sketches to M0 Express
What error messages are you seeing when you try to upload?
- earthres
Here's an image. Hope you can read it!
It's saying "Port busy" which typically means some other software is claiming the COM port.
Have you ever uploaded to an Arduino board on that PC?
- earthres
I've used this Windows 10 computer for YEARS, with many different Arduinos, your HUZZAH32-ESP32, and others. This is the only board I've had problems with. I'm currently using IDE 1.8.15 and I don't have any current plans to change over to the 2. IDE.
OK, so other boards upload OK. ESP32 boards have a slightly different interface, which could be why they are working. Have you used any other M0 based boards?
Can you check COM10 in Device Manager and see if its reporting any issues there?
- earthres
I haven't used any other M0 board. Device Manager says COM10 is "working properly." This window opens when I try to upload anything to the M0Express.
That's the bootloader mode folder. So it's at least getting into bootloader mode.
Does that folder eventually go away? Or does it stay like that after the failed upload?
- earthres
The folder doesn't go away unless I close it myself.
- freddyboomboom
I noticed that in your first screenshot in your original post, you have the Arduino M0 selected as the board.
You should probably select Adafruit M0 Express or something like that, instead.
I don't use Arduino, so I don't have any other suggestions, sorry.
- earthres
Hmm... Considering that you don't use Arduinos at all, why did you make this comment?? Support for all the "Adafruit SAMD Boards" specifically includes the Feather M0 Express. Once this support package is installed, there are three possible choices for M0 boards and I've tried all of them.
@freddyboomboom OMG thanks! That's probably it. Missed it looking at the labels in the port menu select.
@earthres Yep, make sure the board selection is for the Feather M0 Express.
https://learn.adafruit.com/adafruit-fea ... rduino-ide
Should be under:
Tools -> Board -> Adafruit SAMD (32-bits ARM Cortex-M0+ and Cortex-M4) Boards
Should be under:
- earthres
Here are the available boards from IDE 1.8.15
Also install Adafruit SAMD:
https://learn.adafruit.com/adafruit-fea ... md-2854160
You only have Arduino SAMD.
URL to add is shown here:
https://learn.adafruit.com/adafruit-fea ... -ide-setup
- earthres
Well, that really was the problem! My bad, and thanks for your patience!
