"python3": executable file not found in $PATH
clocktower
Post by clocktower »
I am just setting up for an ESP32-S2 Feather under Arduino 1.8.19 on a Mac. Blink tells me "exec: "python3": executable file not found in $PATH".
Any advice?
sj_remington
Re: "python3": executable file not found in $PATH
Post by sj_remington »
clocktower
sj_remington wrote:This may be relevant:
https://forum.arduino.cc/t/python-execu ... le/1008150
Thanks for the effort. It didn't help.
sj_remington
Do you have python3 installed?
If so, where, and where is the IDE looking for it? Post the complete error message.
clocktower
sj_remington wrote:Do you have python3 installed?
I can execute Python3 from Terminal.
The complete error message is:
Error compiling for board Adafruit Feather ESP32-S2.
I believe my Python2 is at "/usr/bin/python"
and Python3 is at "/Library/Frameworks/Python.framework/Versions/3.5/bin/python3"
If I enter Arduino through Terminal I don't get the error message.
sj_remington
Consider adding the python3 executable location to the $PATH variable.
clocktower
sj_remington wrote:Consider adding the python3 executable location to the $PATH variable.
I would love to do that, but I have no idea how to access $PATH in the Arduino app.
adafruit_support_mike
Apple removed Python-2 in macOS 12.2 because it's officially deprecated and abandoned, and doesn't install Python3 by default.
What output do you get from:
which python python3
clocktower
/usr/bin/python
I can execute Python 3.5.2.
Okay, you do have the Python3 intepreter.
What do you get from:
ls -l /usr/bin/py*
clocktower
ls -l /usr/bin/py*
-rwxr-xr-x 4 root wheel 925 Feb 25 2019 /usr/bin/pydoc
lrwxr-xr-x 1 root wheel 74 Mar 15 2019 /usr/bin/pydoc2.7 -> ../../System/Library/Frameworks/Python.framework/Versions/2.7/bin/pydoc2.7
-rwxr-xr-x 1 root wheel 66880 Sep 20 2019 /usr/bin/python
-rwxr-xr-x 4 root wheel 925 Feb 25 2019 /usr/bin/python-config
lrwxr-xr-x 1 root wheel 75 Mar 15 2019 /usr/bin/python2.7 -> ../../System/Library/Frameworks/Python.framework/Versions/2.7/bin/python2.7
lrwxr-xr-x 1 root wheel 82 Mar 15 2019 /usr/bin/python2.7-config -> ../../System/Library/Frameworks/Python.framework/Versions/2.7/bin/python2.7-config
-rwxr-xr-x 1 root wheel 66880 Sep 20 2019 /usr/bin/pythonw
lrwxr-xr-x 1 root wheel 76 Mar 15 2019 /usr/bin/pythonw2.7 -> ../../System/Library/Frameworks/Python.framework/Versions/2.7/bin/pythonw2.7
I might point out that other people have the same error, and ask about it online. Sometimes people say a proposed solution works, sometimes it doesn't. The only one that worked for me was to launch Arduino from within Terminal. The following one worked for some people, but not me:
sed -i -e 's/=python /=python3 /g' ~/Library/Arduino15/packages/esp32/hardware/esp32/*/platform.txt
I've been working my way to a more general and durable solution.
/usr/bin/python --version
If it's some version of Python-3, enter:
sudo ln -s /usr/bin/python /usr/bin/python3
If it's some version of Python-2, enter:
sudo ln -s `which python3` /usr/bin/python3
clocktower
Thanks for your efforts. No luck yet:
Password:
ln: /usr/bin/python3: Operation not permitted
(I entered my password)
Ah.. right. MacOS has security rules that don't allow changes in certain key directories. /usr/bin is one of them.
Try:
sudo sh -c "ln -s `which python3` /usr/local/bin/python3"
The /usr/local file tree isn't locked out.
clocktower
You are persistent! Thank you. But, no luck.
Password:
ln: /usr/local/bin/python3: File exists
Still failure to compile with the following error, but I can still compile if I launch Arduino from within Terminal.
Multiple libraries were found for "WiFi.h"
Used: /Users/bryan/Library/Arduino15/packages/esp32/hardware/esp32/2.0.3/libraries/WiFi
Not used: /Applications/ Bryan's/Arduino/Arduino 1.8.19.app/Contents/Java/libraries/WiFi
