Power profiler with INA219 and ESP32-S2 TFT Feather
AyubowanPro
Re: Power profiler with INA219 and ESP32-S2 TFT Feather
Post by AyubowanPro »
Hello, I did all of that and the timing is the same. I don't know what to do
mikeysklar
Post by mikeysklar »
The last thing to confirm is that voltage and current reading are also taking 2.5ms you are seeing when calling:
  power_mW = ina219.getPower_mW();
You may have come across an issue with the library adding mutli-milisecond delays. You seem to have a short repeatable test case that works for you. Submit it with the ADC SADCRES and BADCRES CONFIG values for 9-bit (0x0000) as that should offer very fast times.
https://github.com/adafruit/Adafruit_INA219/issues
AyubowanPro
I tried with only shunt voltage and current with ADC SADCRES and BADCRES CONFIG values of 9 bit. I'm using Wire.setClock(2560000) and ina219.setCalibration_16V_400mA(). Both shunt and current are taking 1.5ms
I am using this code:
#include <Wire.h>
#include <Adafruit_INA219.h>
Adafruit_INA219 ina219;
#define INA219_CONFIG_BADCRES_MASK (0x0000)
#define INA219_CONFIG_SADCRES_MASK (0x0000)
float current_mA = 0;
void setup(void)
  Serial.begin(115200);
  Wire.setClock(2560000);
  uint32_t currentFrequency;
  if (! ina219.begin()) {
    Serial.println("Failed to find INA219 chip");
    while (1) { delay(10); }
  ina219.setCalibration_16V_400mA();
  Serial.println("Measuring voltage and current with INA219 ...");
void loop(void)
  Serial.println(micros());
  current_mA = ina219.getCurrent_mA();
  Serial.println();
mikeysklar
Thank you for confirming that the voltage and current are taking 1.5ms when they should be running closer to 84uS for samples. This is probably a usage issue around printing out the data through serial or something else causing the slow down. If that is the case then saving samples and printing them after the total sample duration will be helpful. Something you should consider trying.
In the meantime lets have you open an issue with github and see if there is any performance enhancement or known issue with response time on the INA219.
AyubowanPro
Thank you for your reply. I think you're right, the issue might come from printing through serial. I'm going to test it out without printing.
AyubowanPro
So, I tried with this code:
#include <Wire.h>
bool hasRun = 0;
float diff = 0;
typedef struct
      float time_uS;
      float ADCValue;
  }  data_type;
data_type data[2]={};
void setup(void)
void loop(void)
  delay(3000);
  if(hasRun == 0){
    for(int i=0;i<=1;i++){
      data[i].time_uS = micros();
      data[i].ADCValue = ina219.getCurrent_mA();
    diff = data[1].time_uS - data[0].time_uS;
    Serial.print("delay: "); Serial.println(diff);
    hasRun = 1;
I also modified the header file with 0x0 values. There is always 2ms delay between two adc readings.
mikeysklar
It looks like you are on the right track, but your code is still only picking up a single sample and printing the delay. I would think for this to be effective you would have to batch up many samples 10 - 100 and print out a summary.
