Using CP as a development Platform
by wdickenson on Wed May 16, 2018 1:39 pm
I am building a demo and I am using a classic CP as the base. I need to do the development on the road and then when we get to the destination, I need to plug in an extra set of Neopixels, change the number and run. But I wont have access to the neopixels until the day before.
What I would like to do is run a variant of button cycler (NeoPixel demo code) with the pins for the Classic CP. So I would set
#define BUTTON_PIN 4 // Digital IO pin connected to the button. This will be
// driven with a pull-up resistor so the switch should
// pull the pin to ground momentarily. On a high -> low
// transition the button press logic will execute.
#define PIXEL_PIN 17 // Digital IO pin connected to the NeoPixels.
#define PIXEL_COUNT 10
which matches the CP pins. Is that it ? Do I need any other mods ?
Part 2 - when I plug in, i only need to change the PIXEL_PIN to 8 ? rest should work ?
wdickenson
Re: Using CP as a development Platform
by danhalbert on Thu May 17, 2018 10:50 pm
PIXEL_PIN is the pin number that you're going to use for the external NeoPixels. But there is no pin #8 exposed on the board. You want to specify the pin you're planning to use.
https://learn.adafruit.com/introducing- ... utput-pads
Change PIXEL_COUNT to the number of NeoPixels on the external ring or strip.
danhalbert
by nickine9 on Fri May 18, 2018 2:37 am
you may also want to cater for the fact that you might have rgb or rgbw pixels when you define the strip to ring
nickine9
