Windows 10
Circuit Playground Developer Edition ATmega32u4@8MHz
The terminal process terminated with exit code: 1
Terminal will be reused by tasks, press any key to close it.
> Executing task: C:\Users\The Administrator\.platformio\penv\Scripts\platformio.exe run --target upload <
Processing circuitplay_classic (platform: atmelavr; board: circuitplay_classic; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/circuitplay_classic.html
PLATFORM: Atmel AVR > Adafruit Circuit Playground Classic
HARDWARE: ATMEGA32U4 8MHz 2.50KB RAM (28KB Flash)
Library Dependency Finder -> http://BANNED/configure-pio-ldf
LDF MODES: FINDER(chain) COMPATIBILITY(soft)
Collected 25 compatible libraries
Scanning dependencies...
No dependencies
MethodWrapper(["checkprogsize"], [".pioenvs\circuitplay_classic\firmware.elf"])
Memory Usage -> http://BANNED/pio-memory-usage
DATA: [= ] 5.8% (used 149 bytes from 2560 bytes)
PROGRAM: [= ] 14.1% (used 4032 bytes from 28672 bytes)
.pioenvs\circuitplay_classic\firmware.elf :
section size addr
.data 38 8388864
.text 3994 0
.bss 111 8388902
.comment 17 0
.note.gnu.avr.deviceinfo 64 0
.debug_aranges 160 0
.debug_info 3483 0
.debug_abbrev 2510 0
.debug_line 678 0
.debug_str 881 0
Total 11936
<lambda>(["upload"], [".pioenvs\circuitplay_classic\firmware.hex"])
AVAILABLE: avr109
CURRENT: upload_protocol = avr109
BeforeUpload(["upload"], [".pioenvs\circuitplay_classic\firmware.hex"])
Auto-detected: COM10
Forcing reset using 1200bps open/close on port COM10
Waiting for the new upload port...
avrdude -v -p atmega32u4 -C "C:\Users\The Administrator\.platformio\packages\tool-avrdude\avrdude.conf" -c avr109 -b 57600 -D -P "COM9" -U flash:w:.pioenvs\circuitplay_classic\firmware.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\The Administrator\.platformio\packages\tool-avrdude\avrdude.conf"
Using Port : COM9
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
