PWMOut ValueError using stepper motor on Crickit
by AtomicPenguin on Mon Jan 14, 2019 7:15 pm
I am trying to run the Uni-polar Stepper motor demo using the Drive port of the Cricket (with a CPX). I believe the wiring is correct.
When I run (Save) the code, I get the first print statement ("Uni-Polar Stepper motor demo!"), and then nothing happens but I get the following error message in the Serial Monitor (I have inserted a debug print just BEFORE the assignment of the stepper_motor variable.)
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
code.py output:
Just BEFORE assignment of stepper_motor variable
File "code.py", line 9, in <module>
File "adafruit_crickit.py", line 252, in drive_stepper_motor
File "adafruit_crickit.py", line 262, in _motor
File "adafruit_motor/stepper.py", line 82, in __init__
ValueError: PWMOut: 'frequency' must be at least 1500
It appears that the code is barfing on the "stepper_motor = crickit.drive_stepper_motor" statement. The code never gets to the "INTERSTEP_DELAY = 0.02" statement.
I am pretty sure I have updated the CPX and the Cricket firmware.
Any ideas out there?
AtomicPenguin
Re: PWMOut ValueError using stepper motor on Crickit
by adafruit_support_mike on Wed Jan 16, 2019 3:36 am
Could you post a link to the tutorial you're using, or the Github link to the library please?
by AtomicPenguin on Wed Jan 16, 2019 11:39 am
Yes -
Here is the tutorial I am trying to follow: https://learn.adafruit.com/adafruit-cri ... n-steppers
Specifically, I am trying the "Uni-Polar Only Drive Port" example, which uses the crickit.drive_stepper_motor object.
I have updated the latest "Crickit seesaw Firmware" from here: https://github.com/adafruit/seesaw/releases/tag/1.1.4
with the seesaw-crickit.uf2 file. (I note with interest that this refers to a PWM fix.)
Anyway, I also know that the stepper motor is good, because I can run it off an Arduino (full rotation is about 512 steps).
Thanks for your help,
Gary
AtomicPenguin
by adafruit_support_mike on Thu Jan 17, 2019 3:47 am
Thank you. I'll check with the folks who handle the Crickit and CircuitPython code to see what's causing the error.
by colinbotts on Thu Jan 31, 2019 12:52 pm
Similar problems here. I can't get the stepper motor tutorial examples to run, either on the Motor port or the Drive port.
Here's what I get from the serial monitor for the Motor port example:
Bi-Polar or Uni-Polar Stepper motor demo!
File "code.py", line 8, in <module>
File "adafruit_crickit.py", line 247, in stepper_motor
And for the Drive port example:
I have to be honest, I'm getting fairly disappointed by the Crickit. I already posted the other day about it crashing using Makecode (with CPX), and now I'm running into problems with Python. Hopefully these issues can be worked out soon.
colinbotts
by AtomicPenguin on Sun Feb 03, 2019 1:09 pm
Collinbotts: Yes, as a long time, loyal Adafruit cu$tomer, I too hope that the girls and boys at Adafruit will help us out here!
AtomicPenguin
by adafruit_support_mike on Mon Feb 04, 2019 5:23 am
The folks who handle the code are working on resolving the values. I'll check to see where they are in the process.
by asafmatan on Wed Feb 20, 2019 8:52 pm
Also encounter the same issue on both 'Drive' and 'Motor' outputs. Actually Stepper motor is the main reason I bought the Pi Crickit hat. pls help in advising what can be the cause of this issue.
I was able to make it work breakpointing here and setting 1500 freq to ain1 ani2 bin1 bin2 objects (btw it works only for drive port with the motor I tried)
76 def __init__(self, ain1, ain2, bin1, bin2, *, microsteps=16):
77 self._coil = (ain2, bin1, ain1, bin2)
78
79 # reject unsafe (low) pwm freq
80 import ipdb;ipdb.set_trace() <-------
81 for i in range(4):
82 if self._coil[i].frequency < 1500:
83 raise ValueError("PWMOut: 'frequency' must be at least 1500")
asafmatan
by johngale on Sun Feb 24, 2019 6:11 pm
Same issue. Maybe this:
@property
def stepper_motor(self):
"""``adafruit_motor.motor.StepperMotor`` object on Motor 1 and Motor 2 terminals"""
return self._motor(_MOTOR_STEPPER, StepperMotor)
in adafruit_crickit.py
should explicitly set frequency to 1500Hz, instead of leaving it on whatever default it is.
johngale
by 1Adriano on Mon Mar 11, 2019 12:56 pm
Was this issue ever resolved? I recently purchased the crickit and i'm having the same issue.
1Adriano
by adafruit2 on Thu Mar 14, 2019 4:11 pm
hiya sorry this totally slipped thru my ToDo list
The MakeCode crickit issues should be fixed in the latest /beta - they had to completely rewrite the underlying layers (exciting) so please retry it (use adafruit.makecode.com/beta to get the 1.3.x version)
For circuitpython, we reverted a breaking commit here
https://github.com/adafruit/Adafruit_Ci ... /issues/15
we haven't released it yet - will do after we test
adafruit2
Site Admin
by adafruit2 on Thu Mar 14, 2019 10:34 pm
ok tested - try 1.4.1 of the circuitpython *motor* library (not the crickit library)
https://github.com/adafruit/Adafruit_Ci ... r/releases
adafruit2
Site Admin
by dsheeran on Sun Mar 17, 2019 5:44 pm
I tried the fix and it doesn't work. Same problem occurs with the frequency error. Really frustrated.
Perhaps you need to give us better instructions on how to apply the patch.
I tried just moving the lib folder to the D:\CIRCUITPY folder and it copies over and warns of conflicting folders/filenames but then with MU my code still gets the same exception.
Maybe the files are getting replaced but the actual code in memory isn't????
Please assist.
dsheeran
by adafruit2 on Mon Mar 18, 2019 12:28 am
what circuitpython board are you using?
adafruit2
Site Admin
by dsheeran on Mon Mar 18, 2019 7:07 am
Circuit Playground Express
dsheeran
