📬❄️📦Adafruit Holiday Shipping Deadlines 2019: Attention all domestic customers! Please place UPS Ground and USPS First Class & Priority orders by 11am ET Monday December 9, 2019 📬❄️📦 Attention all international customers! Please place all UPS WORLDWIDE EXPRESS; SAVER, and DHL EXPRESS WORLDWIDE orders by 11am ET Monday December 9, 2019 📬❄️📦
NeoPixels and small Servo not working
by criddy on Tue Aug 13, 2019 1:01 am
Hello everyone,
I am trying to run a small Servo and Neopixels on my Playground express. The problem I Keep running into is when I hook them both up they do not work, but if I have just the Neopixels or the servo alone they work. Can the playground express not handle them both?
Here is the code I am using.
let strip: light.NeoPixelStrip = null
forever(function () {
strip = light.createStrip(pins.A1, 12)
strip.setAll(0x00ff00)
light.setAll(0x00ff00)
for (let i = 0; i < 12; i++) {
strip.photonForward(1)
pause(100)
criddy
Re: NeoPixels and small Servo not working
by criddy on Tue Aug 13, 2019 1:03 am
Wrong code sorry. Here is the correct 1
pause(100)
while (true) {
servos.A1.run(50)
criddy
by nickine9 on Tue Aug 13, 2019 3:34 am
how are you powering the pixels and servo? there might not be enough power for them when powered the cpx. you could try a separate power connection for the servo.
nickine9
by criddy on Tue Aug 13, 2019 5:12 am
I just found the info on this. Looks like with the playground express it can not run neopixels and servos together...Sad day
criddy
by nickine9 on Tue Aug 13, 2019 8:16 am
I have used both an external ring and servo at the sometime with the cpx but i powered them from a battery rather than the cpx. you need to connect all the grounds together but it should work.
nick
nickine9
by criddy on Wed Aug 14, 2019 4:09 am
Hello Nick,
I tried to used 12v of power leading to the PGE and still a no go. I think it has something to do with how the code works in PGE. Here is an article I found on it. If you found a workaround and can explain it to me without using another chip let me know.
https://learn.adafruit.com/neopixels-an ... s/overview
criddy
by nickine9 on Wed Aug 14, 2019 6:53 am
hi criddy,
I'm sorry it didn't click before but it looks like you are using the arduino ide, i have used the arduino ide for neopixels and servos but not with the CPX.
you can though use the makecode.org block programming language (which also allows you to use javascript). I dug out an old CPX, 16 neopixel ring and a small servo and got them working together with makecode with both the ring and servo powered from 4*AA batteries. it can be a bit tricky to synchronise servo movement with flashing lights but it can be used for simple projects.
hope that helps
nick
nickine9
