MAX31865
MAX31865
by isuprotein on Wed Aug 28, 2019 11:50 am
I have two MAX31865 boards that I canโ€™t seem to communicate with on my Pi3B+. I have connected them as indicated in https://learn.adafruit.com/adafruit-max ... duino-code. When I run โ€œi2cdetect -y 1โ€ I get
Screen Shot 2019-08-26 at 9.57.45 AM.png (146.96 KiB) Viewed 201 times
I have one of these with the everything soldered on and an RTD1000 connected.
The other I just have pinned to a breadboard.
I believe I have everything installed correctly but I cannot get the CIRCUITPY drive to show up. Any ideas?
isuprotein
Re: MAX31865
by franklin97355 on Wed Aug 28, 2019 12:52 pm
You need the soldered connections for sure. Can you post a picture of the board connected to your Pi?
franklin97355
Re: MAX31865
by isuprotein on Wed Aug 28, 2019 1:42 pm
I thought if there are no soldered connections across the jumper, it would be setup for 4-wire, is that not correct?
Pi picture below
isuprotein
Re: MAX31865
by franklin97355 on Wed Aug 28, 2019 1:55 pm
I'm talking about the connections on the header end. You need to solder a header or jumpers to the board. Check this out. https://learn.adafruit.com/adafruit-max31865-rtd-pt100-amplifier/arduino-code#assembly
franklin97355
Re: MAX31865
by isuprotein on Wed Aug 28, 2019 2:11 pm
I tried it with both boards, the one that is soldered and the one in the picture with the Pi. The soldered one does not give any address with "i2cdetect -y 1" either.
isuprotein
Re: MAX31865
by isuprotein on Sun Sep 08, 2019 7:41 am
I think the root problem of this is that I don't see a CIRCUITPY drive mounted when I connection the board. How do I troubleshot that issue?
isuprotein
Re: MAX31865
by franklin97355 on Sun Sep 08, 2019 12:13 pm
Which Circuit Playground are you connecting to and can we see those connections?
franklin97355
Re: MAX31865
by isuprotein on Fri Sep 13, 2019 8:02 am
I am only connecting the MAX31865 directly to the Pi. I have two MAX31865, one soldered for a three wire sensor and one with only the header pins soldered on. I have tried both of these on two different Pis and can't get either one to show a CIRCUITPY drive.
isuprotein
Re: MAX31865
by franklin97355 on Fri Sep 13, 2019 4:34 pm
You won't get a CIRCUITPY drive on the Raspberry Pi as that is a drive from the Circuit Playground board which you are not using.
franklin97355
Re: MAX31865
by isuprotein on Fri Sep 13, 2019 5:29 pm
That makes sense, I was following the CircuityPython instructions. However, I don't see anything when I run 'i2cdetect -y 1'. How would I troubleshoot that? In the instructions (Installing CircuitPython on Raspberry Pi), I am put to the point where i2c and SPI are enabled and then tested.
isuprotein
Re: MAX31865
by franklin97355 on Sat Sep 14, 2019 1:34 am
When you run that code what do you get?
franklin97355
Re: MAX31865
by isuprotein on Sat Sep 14, 2019 7:56 am
Screen Shot 2019-09-14 at 6.48.11 AM.png (373.72 KiB) Viewed 80 times
isuprotein
Re: MAX31865
by isuprotein on Fri Sep 27, 2019 7:38 am
How can I initiate to send these back or send to you for testing?
isuprotein
Re: MAX31865
by franklin97355 on Fri Sep 27, 2019 10:27 am
Send a note containing a link to this page and your order number to support@adafruit.com. They will get you a refund. You can keep the ones you have but you shouldn't buy another from us as they probably won't work any better as ours are tested before shipping.
franklin97355
