Can't use external I2C devices
by mpc823 on Sat Oct 17, 2020 8:19 pm
I'm trying to run the VL53L0X sample code below, but keep getting the error:
main.py output:
  File "main.py", line 9, in <module>
ValueError: A4 in use
I can't figure out why I can't get use of the I2C clock line.
import time
import board
import busio
import adafruit_vl53l0x
# Initialize I2C bus and sensor.
vl53 = adafruit_vl53l0x.VL53L0X(i2c)
# Main loop will read the range and print it every second.
while True:
    print("Range: {0}mm".format(vl53.range))
    time.sleep(1.0)
mpc823
Re: Can't use external I2C devices
by dastels on Sat Oct 17, 2020 8:57 pm
What board and version of CircuitPython are you using?
dastels
by mpc823 on Sat Oct 17, 2020 9:31 pm
I'm using the Bluefruit CPX and Circuit Python 6 beta. But it appears that after I took everything part and repowered the board things are actually working now. Not sure what happened before, but even across reset it wasn't working. I guess it took actually powering down the board.
Its working now, but thanks for the reply.
mpc823
by mpc823 on Sun Oct 18, 2020 9:52 am
Looks like it only works right after I power cycle everything. But if I try to save my Circuit Python code after any changes, I get the "A4 in use" error. Frustrating.
mpc823
by dastels on Sun Oct 18, 2020 10:42 am
Try using board.I2C to get the i2c object rather than busio and the pins.
dastels
by dastels on Sun Oct 18, 2020 2:43 pm
I just got word that this is being addressed in an upcoming CP 6 build.
dastels
by mpc823 on Sun Oct 18, 2020 3:59 pm
That seems to work. Thanks. Why does that work and busio does not?
mpc823
by dastels on Sun Oct 18, 2020 4:53 pm
I believe board.I2C caches it and so avoid reusing it.
dastels
by tannewt on Mon Oct 19, 2020 8:59 pm
mpc823, could you post your latest code and a picture of your setup so I can try and reproduce? The similar error we found on the MatrixPortal was specific to the MatrixPortal build. Thanks!
tannewt
