I am having difficulty connecting an APDS 9960 to my CPX. For my project I plan to use the color sensor feature.
I used the circuit python sample code from the 9960 learn page (gesture.py) to test the connection. However, when I run the code and enter REPL nothing new prints in the serial window. I only get the >>> prompt. I am able to use the native sensors on the CPX, so I know it works.
Is the CPX compatible with the APDS 9960? I did not load the library, is the library automatically loaded?
I am using a breadboard to connect the sensor to the playground, perhaps a loose connection is responsible.Is that likely? Can I easily test those connections with a multimeter? Perhaps I have overlooked something else.
I have ordered a CLUE and plan to use the color sensor for my project. It looks like they both have STEMMA QT connections. Will they work together connected with a STEMMA QT cable eliminating need for breadboarding?
APDS 9960 and CPX
- dastels
Re: APDS 9960 and CPX
You need to solder the connections to the sensor board. Simply sticking header through the holes and into the breadboard does not work. See https://learn.adafruit.com/adafruit-apd ... t/assembly.
