PinAlarm for MagTag returns button in use error
by Catbar on Sat Jan 02, 2021 10:07 pm
I'm working on an event logger which cycles through a worker list, and which displays a time stamp with the worker's name when the worker pushes a specific button on the MagTag to show when the event was completed. Then, it should go into to deep sleep until the next button press, when it would log the next worker's event time and go back to sleep.
On program startup, I get the first worker name to come up with the current timestamp, but within a few seconds I get an error. No button press is involved.
I'm getting a "BUTTON_x in use" error trying to use the PinAlarm with the most recent CircuitPython and libs for MagTag. Pin D14 returns the error below. Pin D15 returns the error "BUTTON_A in use", etc. The error line, 64, is the first line in the code below that sets the PinAlarm.
I import alarm, alarm.pin, board, time and MagTag from adafruit_magtag.magtag.
The demo programs I found for PinAlarm work fine. I can't see any difference in my code other than my imports.
I'm just sharing just a fragment in case this is obvious, or a known issue. I can post all of my code if this isn't sufficient to diagnose.
pin_alarm = alarm.pin.PinAlarm(pin=board.D14, value=False, pull=True)
board.DISPLAY.refresh()
alarm.exit_and_deep_sleep_until_alarms(pin_alarm)
code.py output:
Connecting to AP ______
Getting time for timezone America/New_York
  File "code.py", line 64, in <module>
ValueError: BUTTON_B in use
Thanks,
Brian
Catbar
Re: PinAlarm for MagTag returns button in use error
by Catbar on Sun Jan 03, 2021 9:00 am
Stripping out all of the references to a MagTag object makes the program work. Just creating a MagTag object, without using it for anything, makes the error occur. So it would seem that the way that I'm creating the PinAlarm won't work if there is also a MagTag object in use. So, there's either a bug in implementation, or something I don't understand yet. I'll try to figure out if it is the latter.
Brian
Catbar
by Catbar on Sun Jan 03, 2021 9:20 am
Here's a stripped down version of the program. If I comment out the "magtag = MagTag()" line, it doesn't fail. Leaving it active generates the "Value error: BUTTON_B in use".
I've not figured out if I'm doing something wrong as of yet, but at least I have a simple representation of the issue.
import alarm
import alarm.pin
import board
from adafruit_magtag.magtag import MagTag
magtag = MagTag()
names_cycle = ("Catherine", "  Brian  ")
if not alarm.wake_alarm:
    alarm.sleep_memory[0] = 0
else:
    if alarm.sleep_memory[0] == 0:
        alarm.sleep_memory[0] = 1
    else:
out = names_cycle[alarm.sleep_memory[0]]
print(out)
Thanks,
Brian
Catbar
by colinj on Thu Jul 22, 2021 8:20 pm
I wanted to give this a BUMP as I'm just starting with the MagTags and I am seeing the same behavior.
So here's the question is it possible to set up a pin alarm while using the MagTag library? Or do I need to move to a lower layer to be able to setup a wake on button type alarm?
Please and thank you
colinj
by colinj on Sun Jul 25, 2021 7:35 pm
As is usually the case soon after I posted this question I discovered the answer—or at least an answer. So, here it is.
To enable an alarm on and of the magtag.peripherals objects you need to deinit() the object because the magtag instance that you created has already grabbed the peripheral and set it up for itself. Here's what my solution looks like:
magtag = MagTag()
magtag.peripherals.buttons[0].deinit()
switch_pronoun_alarm = alarm.pin.PinAlarm(pin=board.BUTTON_A, value=False, pull=True)
alarm.exit_and_deep_sleep_until_alarms(switch_pronoun_alarm)
Immediately after creating the magtag instance use the deinit() function on the object that you want to use at a lower level. Here that is the magtag.peripherals.buttons[0] which corresponds to the board.BUTTON_A object. Once you have freed up the object for use you can then use the peripheral to create something at a lower level, like an alarm.
At least that's the easy way that I've figured out how to do this and still have the rest of the fun MagTag library to play with. Comments, corrections, and criticisms are welcome and appreciated.
colinj
by adafruit_support_carter on Mon Jul 26, 2021 2:21 pm
Looks like there is an open issue for this here:
https://github.com/adafruit/Adafruit_Ci ... /issues/64
