MCP3008 will module throws error when initiating multiple ch
by LaserBread on Sun Oct 03, 2021 9:22 pm
I'm trying to create a controller for Wiz Light Bulbs that use the sliders for different colors using a raspberry pi. My issue is that I can't get the MCP3008 module to read more than one channel without throwing an error in it's backend programs.
Here is the entire code, complete with snarky comments:
#This little test allows me to change the color of a thing using the sliders.
import colour #This is the module that defines Colo(u)r objects allowing me to store them.  Here's where this gets stupid.  So, the module I want isn't a built-in, which is okay.  But python has a module built-in called "color," which does a completely different thing than "colour."  The built-in module influences colors on the terminal, while this one allows colors to be defined as objects.  I hate everything.
import busio
import digitalio
import board
import adafruit_mcp3xxx.mcp3008 as MCP
from adafruit_mcp3xxx.analog_in import AnalogIn
import asyncio
from pywizlight import wizlight, PilotBuilder, discovery
#I want to put this in a function.  But scope is weird.
#CHAPTER 1:  INITIALIZE THE POT
# create the spi bus
spi = busio.SPI(clock=board.SCK, MISO=board.MISO, MOSI=board.MOSI)
# create the cs (chip select)
cs = digitalio.DigitalInOut(board.D22)
# create the mcp object
mcp = MCP.MCP3008(spi, cs)
#Start the Channels.  This is where I encounter the problem.
redChan = MCP.MCP3008(mcp,MCP.P0) #Pot 0 controls red
greenChan = MCP.MCP3008(mcp,MCP.P1) #Pot 1 controls green
blueChan = MCP.MCP3008(mcp,MCP.P2) #Pot 2 controls hamsters
#CHAPTER 2:  C(O/U)L(O(U/E)/(U/E))R
#Initiate the color object to hold our color.
col = Color(redChan,greenChan,blueChan) #NOW WAIT A SECOND!  I THOUGHT THE MODULE WAS CALLED COLOUR!  WHY IS THE OBJECT NAME FROM THE COLOUR PACKAGE SPELLED COLOR!?  WHAT IS THIS MADNESS!?
#CHAPTER 3:  GRAB OUR COLORS!!
def remap_range(value, left_min, left_max, right_min, right_max):
    # this remaps a value from original (left) range to new (right) range
    # Figure out how 'wide' each range is
    left_span = left_max - left_min
    right_span = right_max - right_min
    # Convert the left range into a 0-1 range (int)
    valueScaled = int(value - left_min) / int(left_span)
    # Convert the 0-1 range into a value in the right range.
    return int(right_min + (valueScaled * right_span))
def getColorPot():
    col.red = remap_range(redChan.value,0,65408,0,255)#it's not 65535 because the pot is weird.
    col.green = remap_range(redChan.value,0,65408,0,255)#it's not 65535 because the pot is weird.
    col.blue = remap_range(redChan.value,0,65408,0,255)#it's not 65535 because the pot is weird.
#CHAPTER 4: THE LIGHTS LMFAO
bulbs = []  #Make the bulbs a global variable so all coroutines can access it.
async def discover():
    global bulbs
    #Use UDP to find all the bulbs.
    bulbs = await discovery.discover_lights(broadcast_space="192.168.1.255")
    #read the bulbs
    for bulb in bulbs:
        print(bulb.__dict__)
async def set_color(r,g,b): #Subroutine for setting light colors.  Must be passed RGB values.
    print("setting lights")
    await asyncio.gather(bulbs[0].turn_on(PilotBuilder(rgb = (r,g,b))),bulbs[1].turn_on(PilotBuilder(rgb = (r,g,b))), loop = loop)
#RUNTIME PART
loop = asyncio.get_event_loop()
loop.run_until_complete(discover())
colorLoop = asyncio.get_event_loop()
while(True):
    getColorPot()
    set_color(col.red,col.green,col.blue)
Whenever this code is run, it throws this exception:
File "PiLight/color.py", line 25, in <module>
  File "/usr/local/lib/python3.7/dist-packages/adafruit_mcp3xxx/mcp3008.py", line 61, in __init__
    super().__init__(spi_bus, cs, ref_voltage=ref_voltage)
  File "/usr/local/lib/python3.7/dist-packages/adafruit_mcp3xxx/mcp3xxx.py", line 57, in __init__
    self._spi_device = SPIDevice(spi_bus, cs)
  File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/spi_device.py", line 70, in __init__
    self.chip_select.switch_to_output(value=True)
AttributeError: 'int' object has no attribute 'switch_to_output'
What am I doing wrong? Can someone please help me with this?
LaserBread
Re: MCP3008 will module throws error when initiating multipl
by mikeysklar on Mon Oct 04, 2021 3:42 pm
Skipping the light control and just reading the pot / slider is it working correctly for one channel? eg. If you just use our example code are you able to read MCP.P0 correctly?
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
import busio
import digitalio
import board
cs = digitalio.DigitalInOut(board.D5)
# create an analog input channel on pin 0
chan = AnalogIn(mcp, MCP.P0)
print("Raw ADC Value: ", chan.value)
print("ADC Voltage: " + str(chan.voltage) + "V")
https://github.com/adafruit/Adafruit_Ci ... pletest.py
mikeysklar
by LaserBread on Thu Oct 07, 2021 12:35 am
Yes, it is working properly with one channel.
LaserBread
by mikeysklar on Thu Oct 07, 2021 8:41 am
When you add in a second analog channel to the same code like the following (plus the print lines). What happens?
chan1 = AnalogIn(mcp, MCP.P1)
mikeysklar
by LaserBread on Sun Oct 10, 2021 6:34 pm
I've done that, and it works as intended.
Raw ADC Value for Channel 0:  65472
ADC Voltage: for Channel 0: 3.2968276493476765V
Raw ADC Value for Channel 1:  0
ADC Voltage: for Channel 1: 0.0V
LaserBread
by mikeysklar on Thu Oct 14, 2021 11:17 am
@LaserBread,
In this case the code is working as intended while reading multiple channels on the MCP3008.
Are you able to integrate your light bulb code with a working example in small steps and see if it is possible to isolate what is causing the SPI error.
mikeysklar
