ISSUE WITH THE FIRMATA FIRMWARE
Play with it! Please tell us which board you're using.
luisalazago
Post by luisalazago »
Hi everyone!!
I have a little issue with my Circuit Playground Express. The thing is when I put the firmata firmware file into the unit, the Circuit Playground just stay in a loop of LED colors forever, and it supposes to change to a new unit to drop the Python and Arduino codes.
I've tried to search more information on internet, but I have not answers yet. So I hope if anyone can help me with that.
Thank you'all and have a good day.
mikeysklar
Re: ISSUE WITH THE FIRMATA FIRMWARE
Post by mikeysklar »
Is this the guide you are following:
https://learn.adafruit.com/circuit-play ... ata-sketch
My initial thought is there could be some compatibility issues with running Circuit Playground code on a Circuit Playground Express.
Do you want to try a different example guide to confirm things are working as they should.
https://learn.adafruit.com/adafruit-cir ... nd-express
luisalazago
Greetings,
I understand your point and I'm grateful with your help. But I followed the steps there and I think the problem is the file of the picture that I attached. Becuase, I followed the same steps in three different Circuit Playground Express, and I used the guide that you gave me.
mikeysklar
Since this FIRMATA looks to be almost three years old I'd like to start you off with something more current.
Did you want to develop code using CircuitPython, MakeCode or Arduino?
Let's start with one CPX with the current bootloader and then dropping in the CircuitPython image to make sure the drives are showing up properly and the code is updating. We can then try to run blink.
https://circuitpython.org/board/circuit ... d_express/
https://learn.adafruit.com/adafruit-cir ... quickstart
https://learn.adafruit.com/circuitpytho ... ss/red-led
adafruit2
Post by adafruit2 »
luis, what specifically are you trying to do?
luisalazago
I want to develop Arduino code, but I used the file of the first link that you sent and it doesn't work. On the Circuit Playground when I put the file into the cplayboot the PIN D13 just flicker 3 times and then return to the cplayboot.
mikeysklar
If you wish to develop for Arduino using the Circuit Playground Express follow the main guide for it.
https://learn.adafruit.com/adafruit-cir ... ss/arduino
My original response was asking you which guide you were following,
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
