MakeCode accelerometer VS Circuit python
by Yalfmaster on Tue Oct 19, 2021 5:45 pm
Hi, my project is to merge 2 ideas, I manage to make a custom sound from the buzzer through Circuit python.
The other idea is that I want to trigger this sound when the accelerometer sense more than 8g on the X axis (I succeed with MakeCode but I can't use custom .wav sound)
Does anyone could help me the use the same 8g (or more) trigger but in Circuit python ?
Thanks for the support !
Yalfmaster
Re: MakeCode accelerometer VS Circuit python
by mikeysklar on Thu Oct 21, 2021 5:44 pm
Which model accelerometer?
mikeysklar
by Yalfmaster on Thu Oct 21, 2021 8:16 pm
The onboard one that come with the circuit playground express
Yalfmaster
by mikeysklar on Fri Oct 22, 2021 3:19 pm
@Yalfmaster,
You can use cp.acceleration as the value to determine when to trigger the buzzer.
from adafruit_circuitplayground import cp
while True:
    x, y, z = cp.acceleration
    print(x, y, z)
https://circuitpython.readthedocs.io/pr ... nd-express
You can follow this more lengthy example swapping out the cp.pixels.fill() for cp.play_tone().
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
"""If the switch is to the right, it will appear that nothing is happening. Move the switch to the
left to see the NeoPixels light up in colors related to the accelerometer! The Circuit Playground
has an accelerometer in the center that returns (x, y, z) acceleration values. This program uses
those values to light up the NeoPixels based on those acceleration values."""
# Main loop gets x, y and z axis acceleration, prints the values, and turns on
# red, green and blue, at levels related to the x, y and z values.
while True:
    if not cp.switch:
        # If the switch is to the right, it returns False!
        print("Slide switch off!")
        cp.pixels.fill((0, 0, 0))
        continue
    R = 0
    G = 0
    B = 0
    print((x, y, z))
    cp.pixels.fill(((R + abs(int(x))), (G + abs(int(y))), (B + abs(int(z)))))
https://learn.adafruit.com/circuitpytho ... celeration
cp.play_tone(440, 1)
mikeysklar
