Calibration LMS3MDL with Raspberry Pi using Blinka
Play with it! Please tell us which board you're using.
bsautner
Post by bsautner »
I have a LMS3MDL on a Rasp Pi 4 and I'm trying to calibrate it. The headings I get from it are really inconsistent.
I am able to connect to it with python and get readings though. I'm doing this tutorial:
https://learn.adafruit.com/adafruit-sen ... ing-blinka
The python example gives an error when I run it:
  File "/home/ben/9dof_calibration.py", line 9, in <module>
    from adafruit_lsm6ds import LSM6DSOX
ImportError: cannot import name 'LSM6DSOX' from 'adafruit_lsm6ds' (/home/ben/.local/lib/python3.9/site-packages/adafruit_lsm6ds/__init__.py)
I installed everything so i'm wondering if the tutorial is out of date or i'm missing something
Ben
adafruit_support_carter
Re: Calibration LMS3MDL with Raspberry Pi using Blinka
I think that guide page was written prior to a major refactor in the library layout. So the import syntax shown in the Learn guide needs to be updated.
Try changing the import line from:
to:
from adafruit_lsm6ds.lsm6dsox import LSM6DSOX
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
