1. can I run playgrounds on chromebooks, through what software if so
2. does code.org still support work on playgrounds
3. is there anyone I can actually talk to about playgrounds
When I download the program on my windows laptop and plugged in the playground it does not show the drive to open up the program to try to run it and I also want to use the playground on a chromebook and need to know if that is possible or not
Playground on chromebooks
- mikeysklar
Re: Playground on chromebooks
Are you trying to use a Circuit Playground Express board with your Chromebook (and Windows machine mentioned)?
If so, there is a guide for getting started with a Circuit Playground Express and Chromebooks:
https://learn.adafruit.com/using-circui ... book-setup
The way your post read it sounds as if you are trying to use an app called playgrounds which I'm not familiar with.
