The most common error that I get is that I have a wrong signature.
Arduino: 1.8.2 (Linux), Board: "Adafruit Circuit Playground"
Sketch uses 12816 bytes (44%) of program storage space. Maximum is 28672 bytes.
Global variables use 930 bytes of dynamic memory.
Forcing reset using 1200bps open/close on port /dev/ttyACM1
PORTS {/dev/ttyACM1, } / {} => {}
PORTS {} / {/dev/ttyACM0, } => {/dev/ttyACM0, }
Found upload port: /dev/ttyACM0
/home/neville/Downloads/arduino-1.8.2/hardware/tools/avr/bin/avrdude -C/home/neville/Downloads/arduino-1.8.2/hardware/tools/avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/ttyACM0 -b57600 -D -Uflash:w:/tmp/arduino_build_803377/sketch_jun04a.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 11:00:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/neville/Downloads/arduino-1.8.2/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/neville/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 6.25s
avrdude: Device signature = 0x0d3f0d
avrdude: Expected signature for ATmega32U4 is 1E 95 87
Double check chip, or use -F to override this check.
avrdude done. Thank you.
Wrong microcontroller found. Did you select the right board from the Tools > Board menu?
I have tried changing the USB Cable and using a different USB port in my laptop.
Apparently the board also reinitialize during sketch upload sometimes and gives me this error
Sketch uses 4094 bytes (14%) of program storage space. Maximum is 28672 bytes.
Global variables use 147 bytes of dynamic memory.
An error occurred while uploading the sketch
Forcing reset using 1200bps open/close on port /dev/ttyACM2
PORTS {/dev/ttyACM2, } / {} => {}
PORTS {} / {/dev/ttyACM1, } => {/dev/ttyACM1, }
Found upload port: /dev/ttyACM1
/home/neville/Downloads/arduino-1.8.2/hardware/tools/avr/bin/avrdude -C/home/neville/Downloads/arduino-1.8.2/hardware/tools/avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/ttyACM1 -b57600 -D -Uflash:w:/tmp/arduino_build_488383/Blink.ino.hex:i
Using Port : /dev/ttyACM1
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Device code: 0x44
Reading |
Thanks in advance for any help that you can provide.
