Working with the CPX for a few hours and I think I finally got it working with both the MakeCode and Arduino IDEs because I'm able to upload Arduino sketches and udf2's from MakeCode. However, the CPX doesn't seem very stable and I suspect some kind of driver issue because after just about every upload from either IDE, I lose connectivity to the CPX - the CPX doesn't show on any COM ports and the CPLAYBOOT drive disappears. Doesn't always happen but happens often. Sometimes I get a Widows notification message about a problem with the last USB device connected. Sometimes, I can double-click reset on the CPX to get the green-ring and then the CPLAYBOOT drive and COM ports appear again. But sometimes, I double-click reset on the CPX and get a red-ring and have to reboot the computer or move the CPX to a different USB port to get the CPX to show-up again. I know CPX is still a work in progress so I wanted to ask ... is this normal?
Environment
Win10 Ent, 64-bit, Intel i5, 4GB RAM
Arduino IDE 1.8.3 (not from the Windows Store)
Board Packages
Arduino AVR Boards 1.6.19
Arduino SAMD Boards (32-bits ARM Cortex-M0+) 1.6.15
Adafruit SAMD Boards 1.0.18 (I select CPX from this board package)
Libraries
Adafruit Circuit Playground 1.6.8
Adafruit SleepyDog Library 1.1.1
Notes:
My CPClassic works fine.
I tried installing the adafruit_drivers but it did't help so i removed them.
Device Manager is clear.
I removed two libraries from C:\Program Files(x86)\Arduino that seemed to be getting in the way during compile ... the verbose compiler had found multiple Adafruit_CircuitPlayground.h and was opting to use these instead of the ones I had placed in the libraries folder in my sketchbook location. Not sure if the libraries were important or why the Arduino IDE kept using them when the ones I wanted were in my sketchbook location. The two libraries were...
...arduino_791528
...arduino_879456
Gave it another shot and it looks like I just misunderstood how the CPX (Circuit Playground Express) works. Hopefully this follow-up helps someone:
"Boot Loader" Mode Is Normal - green NeoPixels and red pulsating LED means the CPX is waiting to be programmed.
Double-click the reset button to put it into "boot loader" mode.
Arduino IDE
On each upload, the board enters "boot loader" mode automatically.
The CPX only appears as a drive for the brief time I'm in boot loader mode. The drive disappears after upload completes.
If I try to manually enter boot loader mode before upload, the CPX moves to a different COM port.
Thanks to these videos from Tony D, I get how Makecode and CircuitPython work with CPX ... and I think I'm going to like Circuit Python better than Arduino IDE, at least for CPX ... the interactive aspect is great for experimenting, debugging, etc.: Circuit Playground Express & Windows 10: Make Code & CircuitPython usage with Tony D! https://www.youtube.com/watch?v=FD5lkDypVSo Makecode
In "boot loader" mode, CPX shows as a drive called "CPLAYBOOT". Copy "uf2" file to this drive to program.
After program uploads, your program runs. You are no longer in "boot loader" mode and the "CPLAYBOOT" drive disappears.
Circuit Python (on Windows 10)
Visual Studio Code is a good editor (looks like it might have a serial monitor debugging extension ... interesting)
Use Putty terminal to interact with CPX
Windows S users will have a hard time finding useful editor and serial terminal app in the App Store.
