CP Express IR
Play with it! Please tell us which board you're using.
mpc823
CP Express IR
Post by mpc823 »
I just received some Circuit Playground Express boards and tried out the Arduino sketches for IR transmit (Infrared_Transmit) and IR Receive (Infrared_Read). While both boards seem to be able to receive IR from a Remote Control, I can't seem to get either to transmit to the other. I figure I must be doing something wrong. I am using Arduino 1.8.4, have installed the Circuit Playground Express board package. Is there something special that needs to be done?
Daniel
mpc823
Re: CP Express IR
Post by mpc823 »
So I used the makecode.adafruit.com drag and drop method and was able to confirm that the IR transmit and receive work on both. Seems that the two Circuit Playgrounds shouldn't be directly across from each other, rather they need to be offset from one another. I'm still figuring out exactly how it behaves, but at least I can confirm the HW works.
BTW, the makecode is a really fun way to program stuff up. The event-oriented mechanism that makecode (Javascript) gives you is quite nice.
mpc823
Re: CP Express IR
Post by mpc823 »
So I think there is an error in the Arduino code in file IRLibSAMD21.h. On line 70 it says,
#ifdef ADAFRUIT_CIRCUITPLAYGROUND_M0
when I believe it should be
#ifdef  ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS
My IR sending wasn't working until I made this change. I noticed that when I first installed Arduino 1.8.5, I got example code that had
#if !defined(ADAFRUIT_CIRCUITPLAYGROUND_M0)
  #error "Infrared support is only for the Circuit Playground Express, it doesn't work with the Classic version"
#endif
in the IR examples. After an update, restart and reloading the example code, it changed to
#if !defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS)
#endif
So I think a change was being made in the code that didn't get propagated to this file.
Daniel
adafruit_support_mike
Re: CP Express IR
Good detective work!
I'll have the folks who handle that code take a look.
adafruit2
Re: CP Express IR
Post by adafruit2 »
woosp! fixed :)
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
