I know embedded systems and work with them on a daily basis so this shouldn't be so painful.
I'm using a Mac with the latest OS. I have no problems with the Flora board.
When trying to upload sketches to my CPE I get errors of missing include files.
I reinstalled the Arduino IDE and now I get an error that my board needs to be defined in the board.h file.
I've already deleted the hidden files that are created when running Arduino IDE, which is a poor design choice if you want to teach beginners, and reinstalled Arduino.
What is going on with these boards?
I haven't been able to upload any sketches via the IDE since I got the board.
I'm trying to be positive but the overall experience has been frustrating when you assume this is for learning on your own.
Compile Errors Uploading Sketch to Circuit Playground Expres
- udenjoe
- adafruit_support_mike
Re: Compile Errors Uploading Sketch to Circuit Playground Ex
Have you installed the board support package as shown in the tutorial?
https://learn.adafruit.com/adafruit-cir ... rduino-ide
- udenjoe
CircuitPlayground made it much easier to do. I will use this going forward. Thank you.
- keithellis
I have exactly the same issue. I have followed the tutorial, installed the board support package and can flash the blink sketch, however when I try and flash the switches exampleadafruit_support_mike wrote:Have you installed the board support package as shown in the tutorial?
#include <Adafruit_CircuitPlayground.h>
// Initialize the circuit playground
CircuitPlayground.begin();
// If the left button is pressed....
if (CircuitPlayground.leftButton()) {
CircuitPlayground.redLED(HIGH); // LED on
} else {
CircuitPlayground.redLED(LOW); // LED off
In file included from /Applications/Arduino.app/Contents/Java/libraries/Adafruit_CircuitPlayground/utility/CP_Firmata.h:17:0,
from /Applications/Arduino.app/Contents/Java/libraries/Adafruit_CircuitPlayground/Adafruit_CircuitPlayground.h:23,
from /Users/keithellis/Documents/Arduino/test/test.ino:1:
/Applications/Arduino.app/Contents/Java/libraries/Adafruit_CircuitPlayground/utility/CP_Boards.h:708:2: error: #error "Please edit Boards.h with a hardware abstraction for this board"
exit status 1
Error compiling for board Adafruit Circuit Playground Express.
Thanks, Keith.
- udenjoe
The instructions are not valid or incomplete. Use python instead!
The error messages say you're using the Circuit Playground Classic board support package. Check to make sure you're using a Classic, or switch over to the Circuit Playground Express build target.
