Hi!
I have problems compiling the "CircuitPlaygroundMakeBelieve" Arduino Sketch - See screenshot attached.
I am using Arduino 1.8.5 with installed Arduino SAMD Boards.
Anyone can help?
Thanks in advance!
Regards,
Alex
Circuit Playground Express Error Compiling
- afox
- Bildschirmfoto 2018-02-12 um 19.12.51.png (177.82 KiB) Viewed 418 times
- Franklin97355
Re: Circuit Playground Express Error Compiling
This program is for the Circuit Playground, not the Express.
- adafruit_support_carter
Unfortunately, that sketch will currently only work with the original Circuit Playground Classic. It has some low level code that is trying to access AVR (used on classic) registers directly. These don't exists for the M0 (used on express).
- Kuffcakes
I was working on https://learn.adafruit.com/unicorn-hat- ... -ears/code this project using a Circuit Python Express even though the project uses the Classic. I am having errors with TiCoServo when verifying the code. After removing some of the code, I received: Error compiling for board Adafruit Circuit Playground Express. Am I also out of luck on making this work on the Express?adafruit_support_carter wrote:Unfortunately, that sketch will currently only work with the original Circuit Playground Classic. It has some low level code that is trying to access AVR (used on classic) registers directly. These don't exists for the M0 (used on express).
It looks like the TiCoServo library is also AVR only and so won't work as is with the Circuit Playground Express.
https://learn.adafruit.com/neopixels-an ... vo-library
https://github.com/adafruit/Adafruit_Ti ... vo.cpp#L43
- afox
Ok thanks all for the reply.
Got today the Classic one and wanted to upload the sketch again, but said out of memory on classic.
So i downgraded the Circuit Playground Lib to 1.6.4 and then it let me upload the sketch!
Regards,
Alex
Regards,
Alex
