How to extend the CP NeoPixels??
by tkinsman on Sat Apr 14, 2018 1:12 pm
I have a CP classic, and want to add two of the 8-neopixel strips to it. (To get 26 neopixels total.)
Does anyone know if there is an easy way to get the "Data Out" off the built-in neopixels?
tkinsman
Re: How to extend the CP NeoPixels??
by tkinsman on Sat Apr 14, 2018 4:10 pm
... Or, in other words...
I worry that the neopixel library might only allow one instance of a neopixel string in the system. Does anyone know if I can control the 10 Neopixels on the Circuit Playground ~and~ have another Neopixel strip attached?
tkinsman
by nickine9 on Sun Apr 15, 2018 3:28 am
i have attached a neopixel ring to a cp but treated it as a separate instance running from a different pin to the baked in ones. i don't know if you can piggy back on the internal control pin.
nickine9
by tkinsman on Sun Apr 15, 2018 9:21 pm
Thank you for the information. That means it can be done.
Do you have code handy to share?
tkinsman
by adafruit_support_mike on Mon Apr 16, 2018 6:29 am
There's no easy way to add more NeoPixels to the set that are mounted on the Circuit Playground. The data-out pin for the last pixel doesn't have any connection.
You can use the regular NeoPixel library in parallel with the CircuitPlayground library though.
