I am trying to create John Park's Circuit Playground Password Vault (https://learn.adafruit.com/circuit-play ... t/overview), but I am using a Circuit Playground Express instead of the Circuit Playground Classic. I think that this is possible because I saw the following text listed within the instructions of the Password Vault for Adabox007: "If you'd like to build a more elaborate version of the Password Vault using a Circuit Playground Express or Circuit Playground Classic, that requires an unlock code to use, check out this guide, the Circuit Playground Password Vault!" That said, it seems like I am doing something very wrong as when I hit the switch after loading the code onto the Circuit Playground Express, it seems like a phantom is automatically and systemically keying in false data for the six initial capacitive touch part of the program.
Also, I am getting all sorts of warnings/errors when I try to compile and upload the code with Arduino IDE. These errors end with "Conflicting CPU architectures 0/12."
I know some basics, but I am by no means an expert. I've followed directions as best I can, and have tested the Circuit Playground Express with the basic "Blink' program, and that worked perfectly fine. That said, I still could be overlooking something or making a rookie mistake. In any event, any advice on what I could be doing wrong would be appreciated! Thank you kindly!
Cheers!
Teb
password vault with Circuit Playground Express
- adafruit_support_carter
Re: password vault with Circuit Playground Express
There are some hardware differences between the two boards that may require some code tweaking. But....
we should first figure out why this is happening. If it's not uploading correctly, then that may explain why it's not running correctly. Can you post all of the output you get from this step.Also, I am getting all sorts of warnings/errors when I try to compile and upload the code with Arduino IDE. These errors end with "Conflicting CPU architectures 0/12."
- teb
Thank you for your reply and expertise.
Here is the output that I getting after compiling (part 1 -- too many character to post):Can you post all of the output you get from this step.
(will post part 2 next)/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/teb/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/teb/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/teb/Documents/Arduino/libraries -fqbn=arduino:samd:adafruit_circuitplayground_m0 -vid-pid=0X239A_0X0018 -ide-version=10805 -build-path /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969 -warnings=none -build-cache /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_cache_995741 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=/Users/teb/Library/Arduino15/packages/arduino/tools/openocd/0.9.0-arduino6-static -prefs=runtime.tools.arduinoOTA.path=/Users/teb/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.CMSIS.path=/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.bossac.path=/Users/teb/Library/Arduino15/packages/arduino/tools/bossac/1.7.0 -prefs=runtime.tools.CMSIS-Atmel.path=/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1 -verbose /Users/teb/Downloads/CircuitPlaygroundPasswordVault/CircuitPlaygroundPasswordVault.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/teb/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/teb/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/teb/Documents/Arduino/libraries -fqbn=arduino:samd:adafruit_circuitplayground_m0 -vid-pid=0X239A_0X0018 -ide-version=10805 -build-path /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969 -warnings=none -build-cache /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_cache_995741 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=/Users/teb/Library/Arduino15/packages/arduino/tools/openocd/0.9.0-arduino6-static -prefs=runtime.tools.arduinoOTA.path=/Users/teb/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.CMSIS.path=/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.bossac.path=/Users/teb/Library/Arduino15/packages/arduino/tools/bossac/1.7.0 -prefs=runtime.tools.CMSIS-Atmel.path=/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1 -verbose /Users/teb/Downloads/CircuitPlaygroundPasswordVault/CircuitPlaygroundPasswordVault.ino
Using board 'adafruit_circuitplayground_m0' from platform in folder: /Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18
Using core 'arduino' from platform in folder: /Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18
Detecting libraries used...
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/Adafruit_CircuitPlayground.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_FreeTouch.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_LIS3DH.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_Mic.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_NeoPixel.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_Speaker.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_ZeroPDM.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/CP_Firmata.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/CPlay_CapacitiveSensor.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibDecodeBase.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibHardware.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibProtocols.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibRecvBase.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibRecvPCI.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibSAMD21.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibSendBase.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/ffft.S" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/talkie.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire/Wire.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI/SPI.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src/Keyboard.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID/HID.cpp" -o "/dev/null"
Generating function prototypes...
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp.o"
Compiling libraries...
Compiling library "arduino_296736"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/Adafruit_CircuitPlayground.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/Adafruit_CircuitPlayground.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -x assembler-with-cpp -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/ffft.S" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/ffft.S.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_FreeTouch.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_FreeTouch.cpp.o"
Last edited by adafruit_support_carter on Thu Apr 19, 2018 1:47 pm, edited 1 time in total.
Reason: added [quote] tags
- teb
Here is the second part of the output from compiling (2 of 3):
(part 3 coming next)"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_LIS3DH.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_LIS3DH.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_Mic.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_Mic.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_NeoPixel.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_NeoPixel.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_Speaker.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_Speaker.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_ZeroPDM.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_ZeroPDM.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/CP_Firmata.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/CP_Firmata.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/CPlay_CapacitiveSensor.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/CPlay_CapacitiveSensor.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibDecodeBase.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibDecodeBase.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibHardware.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibHardware.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibProtocols.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibProtocols.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibRecvBase.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibRecvBase.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibRecvPCI.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibRecvPCI.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibSAMD21.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibSAMD21.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibSendBase.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibSendBase.cpp.o"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736/utility" "/Users/teb/Documents/Arduino/libraries/arduino_296736/utility/talkie.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/talkie.cpp.o"
Compiling library "Wire"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire/Wire.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/Wire/Wire.cpp.o"
Compiling library "SPI"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI/SPI.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/SPI/SPI.cpp.o"
Compiling library "Keyboard"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src/Keyboard.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/Keyboard/Keyboard.cpp.o"
Compiling library "HID"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID/HID.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/HID/HID.cpp.o"
Compiling core...
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay/variant.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/core/variant.cpp.o"
Using precompiled core
Linking everything together...
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc" "-L/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969" -Os -Wl,--gc-sections -save-temps "-T/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/CircuitPlaygroundPasswordVault.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/CircuitPlaygroundPasswordVault.ino.elf" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/Adafruit_CircuitPlayground.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/ffft.S.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_FreeTouch.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_LIS3DH.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_Mic.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_NeoPixel.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_Speaker.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_ZeroPDM.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/CP_Firmata.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/CPlay_CapacitiveSensor.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibDecodeBase.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibHardware.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibProtocols.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibRecvBase.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibRecvPCI.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibSAMD21.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibSendBase.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/talkie.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/Wire/Wire.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/SPI/SPI.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/Keyboard/Keyboard.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/HID/HID.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/core/variant.cpp.o" -Wl,--start-group "-L/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/../arduino_cache_995741/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a" -Wl,--end-group
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/ffft.S.o: Conflicting CPU architectures 12/0
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_LIS3DH.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_NeoPixel.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_ZeroPDM.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/CPlay_CapacitiveSensor.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibHardware.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibRecvBase.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibSAMD21.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/talkie.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/SPI/SPI.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/HID/HID.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libm.a(lib_a-sf_fpclassify.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libm.a(lib_a-w_log10.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libm.a(lib_a-e_log10.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libm.a(lib_a-s_lib_ver.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libm.a(lib_a-s_nan.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/../arduino_cache_995741/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(cortex_handlers.c.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/../arduino_cache_995741/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(hooks.c.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/../arduino_cache_995741/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(wiring.c.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/../arduino_cache_995741/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(wiring_digital.c.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/../arduino_cache_995741/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(Print.cpp.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/../arduino_cache_995741/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(SERCOM.cpp.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/../arduino_cache_995741/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(Uart.cpp.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/../arduino_cache_995741/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(abi.cpp.o): Conflicting CPU architectures 0/12
- teb
Re: password vault with Circuit Playground Express
And here is the last part from compiling (3 of 3).
All the best,
Teb
Thank you!"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/CircuitPlaygroundPasswordVault.ino.elf" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/CircuitPlaygroundPasswordVault.ino.bin"
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/../arduino_cache_995741/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(new.cpp.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/../arduino_cache_995741/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(PluggableUSB.cpp.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(_thumb1_case_uqi.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(_divsi3.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(_arm_cmpdf2.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(_fixunsdfsi.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(mulsf3.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(fixsfsi.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(floatunsisf.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(divdf3.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(gedf2.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(muldf3.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(fixdfsi.o): Conflicting CPU architectures 0/12
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/CircuitPlaygroundPasswordVault.ino.elf" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/CircuitPlaygroundPasswordVault.ino.hex"
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(floatunsidf.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(truncdfsf2.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(_clzsi2.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(gesf2.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-aeabi_atexit.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-cxa_atexit.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-exit.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-impure.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-malloc.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-memcpy-stub.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-nano-freer.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-rand.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-strlen.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-strrchr.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-vfprintf.o): Conflicting CPU architectures 0/12
Multiple libraries were found for "Adafruit_CircuitPlayground.h"
Used: /Users/teb/Documents/Arduino/libraries/arduino_296736
Not used: /Users/teb/Documents/Arduino/libraries/Adafruit_Circuit_Playground
Not used: /Applications/Arduino.app/Contents/Java/libraries/Adafruit_Circuit_Playground
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-wbuf.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-abort.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-findfp.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-fwalk.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-memchr-stub.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-nano-reallocr.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-signal.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-stdio.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-writer.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-fstatr.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-lseekr.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-readr.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libnosys.a(close.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libnosys.a(getpid.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libnosys.a(kill.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libnosys.a(read.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libnosys.a(write.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/crtend.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: warning: changing start of section .bss by 4 bytes
Using library arduino_296736 in folder: /Users/teb/Documents/Arduino/libraries/arduino_296736 (legacy)
Using library Wire at version 1.0 in folder: /Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire
Using library SPI at version 1.0 in folder: /Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI
Using library Keyboard at version 1.0.1 in folder: /Applications/Arduino.app/Contents/Java/libraries/Keyboard
Using library HID at version 1.0 in folder: /Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID
Sketch uses 34308 bytes (13%) of program storage space. Maximum is 262144 bytes.
All the best,
Teb
Last edited by adafruit_support_carter on Thu Apr 19, 2018 1:48 pm, edited 1 time in total.
Reason: added [quote] tags
- teb
And lastly, here is the output from uploading:
Cheers,
Teb
Thank you again for any assistance you can provide./Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/teb/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/teb/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/teb/Documents/Arduino/libraries -fqbn=arduino:samd:adafruit_circuitplayground_m0 -vid-pid=0X239A_0X0018 -ide-version=10805 -build-path /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969 -warnings=none -build-cache /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_cache_995741 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=/Users/teb/Library/Arduino15/packages/arduino/tools/openocd/0.9.0-arduino6-static -prefs=runtime.tools.arduinoOTA.path=/Users/teb/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.CMSIS.path=/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.bossac.path=/Users/teb/Library/Arduino15/packages/arduino/tools/bossac/1.7.0 -prefs=runtime.tools.CMSIS-Atmel.path=/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1 -verbose /Users/teb/Downloads/CircuitPlaygroundPasswordVault/CircuitPlaygroundPasswordVault.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/teb/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/teb/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/teb/Documents/Arduino/libraries -fqbn=arduino:samd:adafruit_circuitplayground_m0 -vid-pid=0X239A_0X0018 -ide-version=10805 -build-path /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969 -warnings=none -build-cache /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_cache_995741 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=/Users/teb/Library/Arduino15/packages/arduino/tools/openocd/0.9.0-arduino6-static -prefs=runtime.tools.arduinoOTA.path=/Users/teb/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.CMSIS.path=/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.bossac.path=/Users/teb/Library/Arduino15/packages/arduino/tools/bossac/1.7.0 -prefs=runtime.tools.CMSIS-Atmel.path=/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1 -verbose /Users/teb/Downloads/CircuitPlaygroundPasswordVault/CircuitPlaygroundPasswordVault.ino
Using board 'adafruit_circuitplayground_m0' from platform in folder: /Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18
Using core 'arduino' from platform in folder: /Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18
Detecting libraries used...
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/dev/null"
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/Adafruit_CircuitPlayground.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_FreeTouch.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_LIS3DH.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_Mic.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_NeoPixel.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_CPlay_Speaker.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/Adafruit_ZeroPDM.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/CP_Firmata.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/CPlay_CapacitiveSensor.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibDecodeBase.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibHardware.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibProtocols.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibRecvBase.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibRecvPCI.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibSAMD21.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/IRLibSendBase.cpp
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/ffft.S
Using cached library dependencies for file: /Users/teb/Documents/Arduino/libraries/arduino_296736/utility/talkie.cpp
Using cached library dependencies for file: /Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire/Wire.cpp
Using cached library dependencies for file: /Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI/SPI.cpp
Using cached library dependencies for file: /Applications/Arduino.app/Contents/Java/libraries/Keyboard/src/Keyboard.cpp
Using cached library dependencies for file: /Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID/HID.cpp
Generating function prototypes...
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "-I/Applications/Arduino.app/Contents/Java/libraries/Keyboard/src" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/HID" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/sketch/CircuitPlaygroundPasswordVault.ino.cpp.o"
Compiling libraries...
Compiling library "arduino_296736"
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/Adafruit_CircuitPlayground.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/ffft.S.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_FreeTouch.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_LIS3DH.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_Mic.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_NeoPixel.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_CPlay_Speaker.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/Adafruit_ZeroPDM.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/CP_Firmata.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/CPlay_CapacitiveSensor.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibDecodeBase.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibHardware.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibProtocols.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibRecvBase.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibRecvPCI.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibSAMD21.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/IRLibSendBase.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/arduino_296736/utility/talkie.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/Wire/Wire.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/SPI/SPI.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/Keyboard/Keyboard.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/libraries/HID/HID.cpp.o
Compiling core...
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_30969/core/variant.cpp.o
Atmel SMART device 0x10010005 found
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v1.1 [Arduino:XYZ] May 12 2017 12:19:47
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 0.861 seconds
Write 34672 bytes to flash (542 pages)
[=== ] 11% (64/542 pages)
[======= ] 23% (128/542 pages)
[========== ] 35% (192/542 pages)
[============== ] 47% (256/542 pages)
[================= ] 59% (320/542 pages)
[===================== ] 70% (384/542 pages)
[======================== ] 82% (448/542 pages)
[============================ ] 94% (512/542 pages)
[==============================] 100% (542/542 pages)
done in 0.218 seconds
Verify 34672 bytes of flash with checksum.
Verify successful
done in 0.047 seconds
CPU reset.
Invalid library found in /Users/teb/Documents/Arduino/libraries/arduino_236767: /Users/teb/Documents/Arduino/libraries/arduino_236767
Invalid library found in /Users/teb/Documents/Arduino/libraries/arduino_534522: /Users/teb/Documents/Arduino/libraries/arduino_534522
Invalid library found in /Users/teb/Documents/Arduino/libraries/arduino_649629: /Users/teb/Documents/Arduino/libraries/arduino_649629
Cheers,
Teb
Last edited by adafruit_support_carter on Thu Apr 19, 2018 1:50 pm, edited 1 time in total.
- adafruit_support_carter
I don't see that anywhere in the output. It may not work until you make some software changes, but it looks like it uploaded OK. But let's back up and try something a little more simple. Try running the simple cap touch example below. It should print out the pads to the serial monitor when touched.These errors end with "Conflicting CPU architectures 0/12."
#include <Adafruit_CircuitPlayground.h>
// Circuit Playground Express pads
uint8_t CPX_pads[] = {A1, A2, A3, A4, A5, A6, A7};
// Circuit Playground Classic pads
uint8_t CPC_pads[] = {3, 2, 0, 1, 12, 6, 9, 10};
bool express;
Serial.begin(9600);
CircuitPlayground.begin();
// Check if board is a Circuit Playground Express
express = CircuitPlayground.isExpress();
if (express) {
for (int i=0; i<7; i++) {
Serial.print(CircuitPlayground.readCap(CPX_pads[i]));
Serial.print("\t");
} else {
for (int i=0; i<8; i++) {
Serial.print(CircuitPlayground.readCap(CPC_pads[i]));
Serial.print("\t");
Serial.println();
delay(500);
- teb
Thank you for your reply! I am able to see the "Conflicting CPU architectures 0/12" errors (or mentions?) highlighted in the text I shared by doing a search for "0/12" on this thread. Not sure if that helps or not.
However, when I run the code you provided, I get a stream of seven columns of three digit numbers. When I place my finger on each of the pads (A1 through A7), the number streaming through the serial monitor changes appropriately.
Not sure if this matters or not, but I am still seeing I did notice that I am still seeing that "Conflicting CPU architecture 0/12" -- I'l make one of them bold after I paste the results, but there are many instances of this. Perhaps this doesn't matter. Thank you for your patience!
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/teb/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/teb/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/teb/Documents/Arduino/libraries -fqbn=arduino:samd:adafruit_circuitplayground_m0 -vid-pid=0X239A_0X0018 -ide-version=10805 -build-path /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307 -warnings=none -build-cache /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_cache_394920 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1 -prefs=runtime.tools.arduinoOTA.path=/Users/teb/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.CMSIS-Atmel.path=/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0 -prefs=runtime.tools.CMSIS.path=/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.openocd.path=/Users/teb/Library/Arduino15/packages/arduino/tools/openocd/0.9.0-arduino6-static -prefs=runtime.tools.bossac.path=/Users/teb/Library/Arduino15/packages/arduino/tools/bossac/1.7.0 -verbose /Users/teb/Documents/Arduino/touchpads_test/touchpads_test.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/teb/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/teb/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/teb/Documents/Arduino/libraries -fqbn=arduino:samd:adafruit_circuitplayground_m0 -vid-pid=0X239A_0X0018 -ide-version=10805 -build-path /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307 -warnings=none -build-cache /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_cache_394920 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1 -prefs=runtime.tools.arduinoOTA.path=/Users/teb/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.0 -prefs=runtime.tools.CMSIS-Atmel.path=/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0 -prefs=runtime.tools.CMSIS.path=/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.openocd.path=/Users/teb/Library/Arduino15/packages/arduino/tools/openocd/0.9.0-arduino6-static -prefs=runtime.tools.bossac.path=/Users/teb/Library/Arduino15/packages/arduino/tools/bossac/1.7.0 -verbose /Users/teb/Documents/Arduino/touchpads_test/touchpads_test.ino
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/sketch/touchpads_test.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/sketch/touchpads_test.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/sketch/touchpads_test.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/sketch/touchpads_test.ino.cpp" -o "/dev/null"
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/sketch/touchpads_test.ino.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10805 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON '-DUSB_MANUFACTURER="Adafruit"' '-DUSB_PRODUCT="Circuit Playground Express"' "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/" "-I/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay" "-I/Users/teb/Documents/Arduino/libraries/arduino_296736" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire" "-I/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/sketch/touchpads_test.ino.cpp" -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/sketch/touchpads_test.ino.cpp.o"
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/Adafruit_CircuitPlayground.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/ffft.S.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_CPlay_FreeTouch.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_CPlay_LIS3DH.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_CPlay_Mic.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_CPlay_NeoPixel.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_CPlay_Speaker.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_ZeroPDM.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/CP_Firmata.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/CPlay_CapacitiveSensor.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibDecodeBase.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibHardware.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibProtocols.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibRecvBase.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibRecvPCI.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibSAMD21.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibSendBase.cpp.o
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/talkie.cpp.o
Compiling library "Wire"
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/Wire/Wire.cpp.o
Compiling library "SPI"
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/SPI/SPI.cpp.o
Compiling core...
Using previously compiled file: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/core/variant.cpp.o
Using precompiled core
Linking everything together...
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc" "-L/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307" -Os -Wl,--gc-sections -save-temps "-T/Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/touchpads_test.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/touchpads_test.ino.elf" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/sketch/touchpads_test.ino.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/Adafruit_CircuitPlayground.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/ffft.S.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_CPlay_FreeTouch.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_CPlay_LIS3DH.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_CPlay_Mic.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_CPlay_NeoPixel.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_CPlay_Speaker.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_ZeroPDM.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/CP_Firmata.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/CPlay_CapacitiveSensor.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibDecodeBase.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibHardware.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibProtocols.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibRecvBase.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibRecvPCI.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibSAMD21.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibSendBase.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/talkie.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/Wire/Wire.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/SPI/SPI.cpp.o" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/core/variant.cpp.o" -Wl,--start-group "-L/Users/teb/Library/Arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/../arduino_cache_394920/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a" -Wl,--end-group
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/ffft.S.o: Conflicting CPU architectures 12/0
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_CPlay_LIS3DH.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_CPlay_NeoPixel.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/Adafruit_ZeroPDM.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/CPlay_CapacitiveSensor.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibHardware.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibRecvBase.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/IRLibSAMD21.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/arduino_296736/utility/talkie.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/libraries/SPI/SPI.cpp.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libm.a(lib_a-sf_fpclassify.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libm.a(lib_a-w_log10.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libm.a(lib_a-e_log10.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libm.a(lib_a-s_lib_ver.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libm.a(lib_a-s_nan.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/../arduino_cache_394920/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(cortex_handlers.c.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/../arduino_cache_394920/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(hooks.c.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/../arduino_cache_394920/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(wiring.c.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/../arduino_cache_394920/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(wiring_digital.c.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/../arduino_cache_394920/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(Print.cpp.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/../arduino_cache_394920/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(SERCOM.cpp.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/../arduino_cache_394920/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(Uart.cpp.o): Conflicting CPU architectures 0/12
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/touchpads_test.ino.elf" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/touchpads_test.ino.bin"
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/../arduino_cache_394920/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(abi.cpp.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/../arduino_cache_394920/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(new.cpp.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/../arduino_cache_394920/core/core_arduino_samd_adafruit_circuitplayground_m0_189a7f8702cc3072cc5aee076c8efb87.a(USBCore.cpp.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(_thumb1_case_uqi.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(_divsi3.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(_arm_cmpdf2.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(_fixunsdfsi.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(mulsf3.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(fixsfsi.o): Conflicting CPU architectures 0/12
"/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/touchpads_test.ino.elf" "/var/folders/vz/x9s3z3gx1qs0_g5mfc_xk4yr0000gn/T/arduino_build_420307/touchpads_test.ino.hex"
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(floatunsisf.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(divdf3.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(gedf2.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(muldf3.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(fixdfsi.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(floatunsidf.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(truncdfsf2.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(_clzsi2.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(gesf2.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-aeabi_atexit.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-cxa_atexit.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-exit.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-impure.o): Conflicting CPU architectures 0/12
Multiple libraries were found for "Adafruit_CircuitPlayground.h"
Used: /Users/teb/Documents/Arduino/libraries/arduino_296736
Not used: /Users/teb/Documents/Arduino/libraries/Adafruit_Circuit_Playground
Not used: /Applications/Arduino.app/Contents/Java/libraries/Adafruit_Circuit_Playground
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-malloc.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-memset.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-nano-mallocr.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-sbrkr.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-strncpy.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-strstr.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-vfprintf_i.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-wsetup.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-fflush.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-fvwrite.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-makebuf.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-memmove.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-reent.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-signalr.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-strchr.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-closer.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-isattyr.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libc_s.a(lib_a-nano-msizer.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/libgcc.a(_muldi3.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libnosys.a(fstat.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libnosys.a(isatty.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libnosys.a(lseek.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libnosys.a(sbrk.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libnosys.a(_exit.o): Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/armv6-m/crtn.o: Conflicting CPU architectures 0/12
/Users/teb/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: warning: changing start of section .bss by 4 bytes
Using library arduino_296736 in folder: /Users/teb/Documents/Arduino/libraries/arduino_296736 (legacy)
Using library Wire at version 1.0 in folder: /Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/Wire
Using library SPI at version 1.0 in folder: /Users/teb/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/libraries/SPI
Sketch uses 31548 bytes (12%) of program storage space. Maximum is 262144 bytes.
Chip ID : 10010005
Address : 8192
Pages : 3968
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : true
BOR : true
Erase flash
done in 0.845 seconds
Write 31848 bytes to flash (498 pages)
[=== ] 12% (64/498 pages)
[======= ] 25% (128/498 pages)
[=========== ] 38% (192/498 pages)
[=============== ] 51% (256/498 pages)
[=================== ] 64% (320/498 pages)
[======================= ] 77% (384/498 pages)
[========================== ] 89% (448/498 pages)
[==============================] 100% (498/498 pages)
done in 0.200 seconds
Verify 31848 bytes of flash with checksum.
Verify successful
done in 0.043 seconds
CPU reset.
Last edited by adafruit_support_carter on Thu Apr 19, 2018 4:02 pm, edited 1 time in total.
Reason: added [quote] tags
Re: password vault with Circuit Playground Express
Sorry. I see it now. I must have messed up my text search trying to look for it.
It looks like something is just a little off with your Arduino setup.
Do you remember or know why there's the folder /Users/teb/Documents/Arduino/libraries/arduino_296736?Multiple libraries were found for "Adafruit_CircuitPlayground.h"
- teb
I don't remember, but it would be fine to remove whatever you think I should. Some things seems to have been placed in there possibly from iCloud synching.Do you remember or know why there's the folder /Users/teb/Documents/Arduino/libraries/arduino_296736?
Also noticed that the values I was getting from the cap pads program you sent me were in the 189 to 278 range. I went in the John Park's code and it seemed like the program was looking for values over 25. I am by no means a programmer and don't really know what I am doing, but figured it would be worth a try to change the code so things wouldn't be triggered unless this value was above 300. I made that change, and it did mostly help.
//Code entry.
//Allow unlock code to be entered using capacitive pads
if ((codePrompt == 0)&&(passPrompt==0)) { //do nothing until code prompt flips
return;
else if ((codePrompt == 1)&&(passPrompt==0)) {//check the cap switches for entry
int cap1=CircuitPlayground.readCap(1);
int cap3=CircuitPlayground.readCap(3);
int cap10=CircuitPlayground.readCap(10);
int cap12=CircuitPlayground.readCap(12);
if (cap1<300 && cap3<300 && cap10<300 && cap12<300) {
return;
else if (cap1>300) {
codeEntry[n]=1;//add code entry to the array
//light a pixel yellow
CircuitPlayground.setPixelColor(n,255,255,0);
n++;
delay(400);
else if (cap3>300) {
codeEntry[n]=3;//add code entry to the array
n++;
delay(400);
else if (cap10>300) {
codeEntry[n]=10;//add code entry to the array
n++;
delay(400);
else if (cap12>300) {
codeEntry[n]=12;//add code entry to the array
n++;
delay(400);
All the best,
Teb
- teb
Just tried making the pad cap code to something that didn't include the A0 pad, with the altered code that increased the values to greater than 300. It worked. If possible would like to make all four of the cap pads work and would like to understand why the range is so different. Thank you for getting me this far!
All the best,
Teb
All the best,
Teb
Nice. You've discovered several of the hardware differences. A0 on the CPX is not available for touch:
https://learn.adafruit.com/adafruit-cir ... s#each-pin
Additionally, the raw touch values generated are different between the CPC (classic) and the CPX. So, as you've tried playing around with, those value would need to be changed. You could use that simple sketch I included above as a way to test what these values are for each pin.
For the weirdness with your Arduino setup. You can either just keep using it as is, since it seems like it's uploading code OK. If you wanted to try and fix it, I think it might be easiest to just reinstall it. If you go that route, also delete this folder before you do the reinstall:
to make sure things start fresh.
- johnpark
Good job hunting down the problem -- I'll update the guide to reflect both the differences in cap values between boards, as well as the A0 being off limits on CPX.
Best,
John
Best,
John
- teb
Thank you, @adafruit_support_carter for guiding me through this the process --- I very much enjoyed the process of trying to figure this out and appreciate your help. And thank you, @johnpark, for creating this project in the first place and sharing it!
Cheers,
Teb
Cheers,
Teb
- johnpark
