/* Infrared_Record.ino Example sketch for IRLib2 and Circuit Playground Express
Illustrates how to receive an IR signal, decode and save it.
Then retransmit it whenever you push the left pushbutton.
The error is "Infrared support is only for the Circuit Playground Express, it doesn't work with the Classic version"
I really use the circuit playground express. I selected the board circuit playground express already and com port already. Why? When I press the left button , in the serial monitor" No signal saved yet."
Please help! Thanks.
Infrared_Record.ino does not work
Re: Infrared_Record.ino does not work
Enable verbose messages during compilation in the Arduino IDE's preferences, try to compile the sketch again, and post the output in the debug pane between CODE tags please.
- mpc823
I just did a fresh install of Arduino 1.8.5 onto a USB stick and had this same issue.
Look here - viewtopic.php?f=58&t=125346 for the way around it that I used.
I'm surprised this is still an issue.
Daniel
Daniel
